Question Bsod, kernel power crash.
Hi, So need a little advice; i was browsing the web when all of a sudden the screen went black with keyboard and mouse lights off and then rebooted itself;
So when i checked event viewer there was a Kernel Power Error.
So then i downloaded bluescreenview,and there was a dmp file just few seconds earlier;
030925-6062-01.dmp 09-03-2025 04:03:21 PAGE_FAULT_IN_NONPAGED_AREA 0x00000050 ffff8087`11b8fa80 00000000`00000002 fffff803`96c9b1db 00000000`00000002 ntoskrnl.exe ntoskrnl.exe+4b7ce0 x64 ntoskrnl.exe+4b7ce0
kernel error:
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 09-03-2025 04:03:37
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (70368744177664),(2)
User: SYSTEM
Computer: DESKTOP-3NU5HK7
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Gskill ddr4 3200 mts
PC Specs
Motherboard: Asus EXB760M (new just a few days ago)
CPU: i5-12400F
GPU: RX 6800XT
PSU: Corsair RM750X
SSD: ADATA Legend 710
why did you replace the motherboard
was windows installed freshly after changing the motherboard?
bios of the motherboard up to date?
pins of the motherboard socket were not bent while installing the CPU?
temperatures of cpu and gpu fine while under load?
check windows with dism commands
check RAM with memory test
check hard drives and eventually update the firmware with manufacturer´s tool, e.g. ADATA´s toolbox:
