Bsod Memory management, Irql not less or equal among others.
Dregoran
Commendable
Aug 18, 2016
13
Recently put together my Ryzen 1700x build and from day 1 I'm having random BSOD issues. Nothing in particular seems to cause it, happens whether I'm gaming or just browsing. It's most commonly memory management, but I've also had irql not less or equal, Faulty Hardware corrupted page and Critical Structure Corruption.
Everything I've researched points to drivers or ram issues. So I tested each stick individually and they both still crash and I also ran memtestx86 with no errors. I updated all drivers and even tried disabling the on board audio as I guess that can be one of the main culprits and I use a hyperx cloud 2 with it's own soundcard so I didn't need the onboard anyway. I'm basically making no progress with my little knowledge on troubleshoot so I'm here with my dump files hoping someone more knowledgeable may have an answer.
Here is a link to th eonedrive containing my dump files. Any help would be greatly appreciated.
https://1drv.ms/f/s!ApOT9jMfaCBAgmcpaQ7gfOmQuq27
Just try a different slot, just to rule out a motherboard issue. If you still BSOD, then it's probably a driver issue. You'll probably have a bit more luck in one of the Windows subforums if you need additional assistance.
I did yea, I assumed memtest would throw an error either way. Should I try it in a different slot? I just used the recommended slot that the book says to use when using only 1 stick. Also would you recommend 1 at a time again or throw them both in to 1 and 3?
