BSOD, Need help finding out what is causing it.
brownie1992
21
For the past couple days i have been getting hard crashes, They seem to happen randomly.
I get this message: critical structure corruption win32k.sys
I have no idea what it is or how to fix it, how do i read dump files to determine what is the problem, or is their someone i can contact.
Thanks for any help.
Hi brownie, might be you have problem of one of your hardware inside either the RAM, you can use this program link here: www.tweakbit.com/land/fix-my-pc/support?build=7fFMPd&instructions=1&content=bsod&kw=BSOD&utm_source=sevenforums.com&utm_medium=link&utm_campaign=Sevenforums.1, if you can't, check your memory perform a memory test or try to replace it with compatible one and check also your BIOS support.
