Hey guys, I got a BSOD. I need help figuring out what the dump file says. Heres the debugged dumpfile:
Crash Dump Analysis provided by OSR Open Systems Resources, Inc. (http://www.osr.com)
Online Crash Dump Analysis Service
See http://www.osronline.com for more information
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 9600.17238.amd64fre.winblue_gdr.140723-2018
Machine Name:
Kernel base = 0xfffff800`3127d000 PsLoadedModuleList = 0xfffff800`31547350
Debug session time: Thu Oct 2 20:49:48.834 2014 (UTC - 4:00)
System Uptime: 0 days 0:16:53.501
* Bugcheck Analysis *
CRITICAL_STRUCTURE_CORRUPTION (109)
This bugcheck is generated when the kernel detects that critical kernel code or
data have been corrupted. There are generally three causes for a corruption:
1) A driver has inadvertently or deliberately modified critical kernel code
or data. See http://www.microsoft.com/whdc/driver/kernel/64bitPatching.mspx
2) A developer attempted to set a normal kernel breakpoint using a kernel
debugger that was not attached when the system was booted. Normal breakpoints,
"bp", can only be set if the debugger is attached at boot time. Hardware
breakpoints, "ba", can be set at any time.
3) A hardware corruption occurred, e.g. failing RAM holding kernel code or data.
Arguments:
Arg1: a3a01f597b101753, Reserved
Arg2: b3b72bdfcd8d59d6, Reserved
Arg3: fffff800313baad0, Failure type dependent information
Arg4: 0000000000000001, Type of corrupted region, can be
0 : A generic data region
1 : Modification of a function or .pdata
2 : A processor IDT
3 : A processor GDT
4 : Type 1 process list corruption
5 : Type 2 process list corruption
6 : Debug routine modification
7 : Critical MSR modification
Debugging Details:
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
BUGCHECK_STR: 0x109
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: CODE_CORRUPTION
PROCESS_NAME: csrss.exe
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from 0000000000000000 to fffff800313d0ca0
STACK_TEXT:
ffffd001`b232e088 00000000`00000000 : 00000000`00000109 a3a01f59`7b101753 b3b72bdf`cd8d59d6 fffff800`313baad0 : nt!KeBugCheckEx
STACK_COMMAND: kb
MODULE_NAME: memory_corruption
IMAGE_NAME: memory_corruption
FOLLOWUP_NAME: memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MEMORY_CORRUPTOR: ONE_BIT
FAILURE_BUCKET_ID: X64_MEMORY_CORRUPTION_ONE_BIT
Followup: memory_corruption
Machine Name:
Arguments:
2 : A processor IDT
3 : A processor GDT
Debugging Details:
BUGCHECK_STR: 0x109
CURRENT_IRQL: 2
STACK_TEXT:
STACK_COMMAND: kb
