Bsod need help
Bonggyver
Commendable
Apr 20, 2016
6
This is what came up when i ran debugging tool
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa800dc1e028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000bf800000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000124, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR: 0x124_GenuineIntel
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
PROCESS_NAME: TrustedInstall
CURRENT_IRQL: f
ANALYSIS_VERSION: 6.3.9600.17336 (debuggers(dbg).150226-1500) amd64fre
STACK_TEXT:
fffff880`035eeb58 fffff800`03a07a3b : 00000000`00000124 00000000`00000000 fffffa80`0dc1e028 00000000`bf800000 : nt!KeBugCheckEx
fffff880`035eeb60 fffff800`03597e63 : 00000000`00000001 fffffa80`0db20ea0 00000000`00000000 fffffa80`0db20ef0 : hal!HalBugCheckSystem+0x1e3
fffff880`035eeba0 fffff800`03a07700 : 00000000`00000728 fffffa80`0db20ea0 fffff880`035eef30 fffff880`035eef00 : nt!WheaReportHwError+0x263
fffff880`035eec00 fffff800`03a07052 : fffffa80`0db20ea0 fffff880`035eef30 fffffa80`0db20ea0 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`035eed50 fffff800`03a06f0d : 00000000`00000008 00000000`00000001 fffff880`035eefb0 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`035eed90 fffff800`039fae88 : fffffa80`1d874c00 00000000`00000002 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0x55
fffff880`035eedc0 fffff800`0347beac : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40
fffff880`035eedf0 fffff800`0347bd13 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`035eef30 fffff800`035b5e28 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
fffff880`0df4a840 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!ExFreePoolWithTag+0x98
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: GenuineIntel
IMAGE_NAME: GenuineIntel
DEBUG_FLR_IMAGE_TIMESTAMP: 0
IMAGE_VERSION:
FAILURE_BUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_CACHE
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:x64_0x124_genuineintel_processor_cache
FAILURE_ID_HASH: {270f58cb-a20a-a72d-6d81-eb8c82f01f7a}
Followup: MachineOwner
I asked because one of the Dumps has OVERLAPPED_MODULE: Address regions for 'BHDrvx64' and 'BHDrvx64.sys' overlap, Thinking this points towards norton having issues playing nice with your other drivers/app
Mark_1970
1,391
I am not joining 4shared just to look at those or downloading HDVideoPlayer or anything else it wants me to download/install. You may need to find a better solution as people will shy away from doing that
AceScottie
143
cant you either tell us the stop code or post the picture somewhere we can just view it (no downloads)
anyway. SDtandard BSOD reasons.
1: you ran out of RAM, make sure your backgroud applications are closed and your not running 9 million junk apps and toolbard.
2: your tried overclocing and messed it up. Undo the OC or look for a stabler OC.
3: you ran something you shouldnt have. Check the last thing you ran and dont run it again if you dont recognise it.
Also check Administration Tools > Event Viewer and look for Errors. if you find some google them to see what they mean and if you should be worried about them.
other help about your issue here: http://www.sevenforums.com/crash-lockup-debug-how/35349-stop-0x124-what-means-what-try.html
Mark_1970
1,391
Bonggyver
Commendable
Apr 20, 2016
6
Ran norton removal tool to make sure everything from norton was uninstalled computer hasn't crashed since I did that 2 hours ago pretty sure that was the problem. What's a good Antivirus I can use? Wasn't supposed to get Norton again but forgot to cancel subscription before renewal
Bonggyver
Commendable
Apr 20, 2016
6
Already installed Microsoft Security essentials when I ran norton removal tool wasn't planning on using norton anymore. My computer is only used for gaming and watching twitch streams don't really do anything else.
