Hey guys
system specs
i3 6100
R9 380 2gb
8gb DDR4 (one stick)
550w corsair psu
so in the past (two weeks?) maybe i've been getting bluescreen crashes while playing games
and after research people suggested The software WhoCrashed
and here's the info i've got
note that yesterday i did a fresh reinstall for my GPU i think it was after the last atikmdag.sys crash
On Thu 9/8/2016 05:23:41 ص GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\090816-15125-01.dmp
This was probably caused by the following module: atikmdag.sys (0xFFFFF801DC0BDF91)
Bugcheck code: 0x50 (0xFFFFD001EEE7E898, 0x0, 0xFFFFF801DC0BDF91, 0x0)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: C:\WINDOWS\system32\drivers\atikmdag.sys
product: ATI Radeon Family
company: Advanced Micro Devices, Inc.
description: ATI Radeon Kernel Mode Driver
Bug check description: This indicates that invalid system memory has been referenced.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmdag.sys (ATI Radeon Kernel Mode Driver, Advanced Micro Devices, Inc.).
Google query: Advanced Micro Devices, Inc. PAGE_FAULT_IN_NONPAGED_AREA
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: atikmdag.sys (atikmdag+0x11DF91)
On Wed 9/7/2016 11:11:40 ص GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\090716-21078-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x142940)
Bugcheck code: 0xA (0x28, 0x2, 0x0, 0xFFFFF80138573503)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Wed 9/7/2016 04:15:12 ص GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\090716-19312-01.dmp
Bugcheck code: 0xA (0x28, 0x2, 0x0, 0xFFFFF8003BAF6503)
On Mon 9/5/2016 02:22:36 ص GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\090516-13625-01.dmp
Bugcheck code: 0xA (0x28, 0x2, 0x0, 0xFFFFF802CCF6E503)
On Wed 8/31/2016 08:11:10 م GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\083116-18500-01.dmp
Bugcheck code: 0xA (0x28, 0x2, 0x0, 0xFFFFF801C5CFE503)
Conclusion
6 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination with the errors that have been reported for these drivers. Include the brand and model name of your computer as well in the query. This often yields interesting results from discussions on the web by users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
system specs
i3 6100
R9 380 2gb
550w corsair psu
Conclusion
