BSOD on Wake up Driver Power State Failure 0x9F
Kevin Deuel
39
I just bought a new Hard Drive and DVD Drive a Seagate 750 raptor 10000rpm and a lite-on DVD Drive my system is as follows:
MB: ASUS M5A99X EVO
Processor: AMD FX 8300 @ 4.4Ghz
RAM: Kingston Hyper X 32GB @1866Mhz
GC: Readon HD 7770 @ 2GB
HD Setup: 750GB SG Raptor Primary @ 10000rpm / SG 1TB @ 7200rpm / WD 320GB @ 5200RPM / WD 160 GB @ 5200 RPM
So ever since I installed the new HD and installed windows 8 I have been having BSOD issues on wake up from sleep with the error message Drive Power State Failure I downloaded WhoCrashed and the report it passed me was as follows:
On Sun 1/25/2015 5:12:20 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\012515-28078-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x14F1A0)
Bugcheck code: 0x9F (0x3, 0xFFFFE0019B227610, 0xFFFFF803570548E0, 0xFFFFE0019ED2E460)
Error: DRIVER_POWER_STATE_FAILURE
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Sun 1/25/2015 3:57:21 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\012415-39812-01.dmp
Bugcheck code: 0x9F (0x3, 0xFFFFE00158E29060, 0xFFFFF803652548E0, 0xFFFFE00158A1ADC0)
On Fri 1/23/2015 4:20:54 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\012315-182859-01.dmp
This was probably caused by the following module: Unknown ()
Bugcheck code: 0x0 (0x0, 0x0, 0x0, 0x0)
Error: CUSTOM_ERROR
A third party driver was identified as the probable root cause of this system error.
Google query: CUSTOM_ERROR
You have a 3rd party hardware device driver installed that is not correctly handling low power sleep state requests. That is, a device is told to go to a low power state (sleep) and it does it incorrectly.
for example it goes to sleep without processing pending requests, or goes to sleep but does not respond when asked to wake up.
This is very common for some USB wireless devices. The general procedure for fixing it is:
update BIOS (to get USB BIOS fixes)
update CPU chipset drivers (if you have intel cpu get driver here https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=20775
update external USB 3.0 chipset drivers (from chipset vendor or motherboard vendor)
Now you need to update the actual USB wireless device driver if you can get a current copy.
you might use the powercfg.exe /energy command to help find the problem (start cmd.exe as an admin, run the command and look at the report)
you could also, change your minidump type to full, wait until you get the next bugcheck, put the full memory dump on a server and have some one use the windows debugger to tell you what the problem is.
