[SOLVED] BSOD over and over then perfectly fine for days
sorry I obviously didn't watch this thread after giving gman the link
What is this for?
Aug 13 2015zttap300.sysZeroTier Networks TAP driver
Amd themselves may suggest you don't use this, depends on CPU I think
Dec 04 2012amdide64.sysAMD SATA Controller driver http://support.amd.com/
MD SATA AHCI drivers for AMD 6-Series, 7-Series, 8-Series, or 9-Series chipsets are included in the chipset driver package and is compatible only with desktop systems running Windows® 8.1, Windows 7 or older (depending on chipset).
The AMD SATA controller component is not compatible with and will not be offered nor installed by the chipset...
Hi, I ran the dump files through the debugger and got the following information: https://jsfiddle.net/b0uxfqy6/show This link is for anyone wanting to help. You do not have to view it. It is safe to "run the fiddle" as the page asks.
File information:011521-9437-01.dmp (Jan 16 2021 - 00:17:16)
Bugcheck:IRQL_NOT_LESS_OR_EQUAL (A)
Probably caused by:memory_corruption (Process: Discord.exe)
Uptime:0 Day(s), 0 Hour(s), 17 Min(s), and 35 Sec(s)
File information:011521-9359-01.dmp (Jan 16 2021 - 00:20:05)
Probably caused by:memory_corruption (Process: System)
Uptime:0 Day(s), 0 Hour(s), 01 Min(s), and 40 Sec(s)
File information:011521-9187-01.dmp (Jan 16 2021 - 00:56:33)
Uptime:0 Day(s), 0 Hour(s), 16 Min(s), and 58 Sec(s)
File information:011521-9000-01.dmp (Jan 16 2021 - 00:25:22)
Bugcheck:KMODE_EXCEPTION_NOT_HANDLED (1E)
Uptime:0 Day(s), 0 Hour(s), 04 Min(s), and 27 Sec(s)
File information:011521-13421-01.dmp (Jan 15 2021 - 23:36:34)
Bugcheck:ATTEMPTED_WRITE_TO_READONLY_MEMORY (BE)
Uptime:2 Day(s), 2 Hour(s), 30 Min(s), and 11 Sec(s)
Comment: 2 or more types of RAM are installed.
Comment: The overclocking driver "AODDriver2.sys" was found on your system. (AMD Overdrive)
Possible Motherboard page: https://www.asrock.com/mb/AMD/Fatal1ty 970 Performance/
You have the latest BIOS already installed.
This information can be used by others to help you. Someone else will post with more information. Please wait for additional answers. Good luck.
You are using 2 different types of RAM. Sometimes this will work, sometimes it won't. Sometimes they are not compatible with one another and cause BSODs. It appears as if you have 3 sticks that are the same, and 1 stick that is different.
SizeSpeedManufacturerPart No.
4096MB1600MHzUndefinedF3-2400C11-4GXM
4096MB1600MHzUndefinedF3-2133C9-4GXL
I ran the new dump files through the debugger and got the following information: https://jsfiddle.net/0t2pw174/show This link is for anyone wanting to help. You do not have to view it. It is safe to "run the fiddle" as the page asks.
File information:012121-9765-01.dmp (Jan 21 2021 - 02:17:47)
Bugcheck:KERNEL_SECURITY_CHECK_FAILURE (139)
Probably caused by:ntkrnlmp.exe (Process: System)
Uptime:0 Day(s), 0 Hour(s), 03 Min(s), and 06 Sec(s)
File information:012121-9609-01.dmp (Jan 21 2021 - 21:20:58)
Probably caused by:memory_corruption (Process: steamwebhelper)
Uptime:0 Day(s), 0 Hour(s), 09 Min(s), and 37 Sec(s)
File information:012121-9281-01.dmp (Jan 21 2021 - 01:51:54)
Uptime:0 Day(s), 0 Hour(s), 53 Min(s), and 17 Sec(s)
File information:012121-7671-01.dmp (Jan 21 2021 - 02:14:11)
Probably caused by:ntkrnlmp.exe (Process: MsMpEng.exe)
Uptime:0 Day(s), 0 Hour(s), 21 Min(s), and 06 Sec(s)
File information:012121-10046-01.dmp (Jan 21 2021 - 21:30:07)
Probably caused by:memory_corruption (Process: EscapeFromTark)
Uptime:0 Day(s), 0 Hour(s), 05 Min(s), and 00 Sec(s)
I've reminded Colif about this thread. He should reply sometime later today. Good luck.
Strange update, all ram sticks have the same part number and such. Likely will be buying new ones if this solves it as I'm thinking one could've been a chinese fake seeing how the parts are used
What is this for?
The AMD SATA controller component is not compatible with and will not be offered nor installed by the chipset driver package on AMD desktop systems running Window® 10 or using AMD Socket AM4 and Socket TR4 chipsets. Forcing a manual driver installation via Device Manager on these systems is not supported and may cause stability and performance issues with some mass storage devices, such as solid-state drives (SSD).
Recommendations
Desktop systems based on AMD 6-Series, 7-Series, 8-Series, 9-Series, Socket AM4, and Socket TR4 chipsets running Windows® 10 should use the Microsoft provided Standard SATA AHCI Controller driver that comes installed with Windows® by default. This configuration ensures compatibility and offers the best experience with most types of mass storage devices.
https://www.amd.com/en/support/kb/faq/pa-250
try updating lan drivers
Sep 28 2020rt640x64.sysRealtek NICDRV 8169 PCIe GBE Family Controller driver https://www.realtek.com/en/
not that old but are newer here under windows - 3rd link down - https://www.realtek.com/en/componen...0-1000m-gigabit-ethernet-pci-express-software
