BSOD Problem + MemTest86 Results Clarification
Darius Bieber
15
Hello everyone. I would like to thank you guys in advance for any help!
I have an HP dv7 Pavilion that is a little over 2 years old. About 9 months ago, I would occasionally get a BSOD while streaming sports (WatchESPN or First Row) while using HDMI to my TV. Otherwise, I would never get the BSOD while browsing the internet or playing games on High Definition.
After reading through some other threads, many suggested this is a RAM issue. My BSOD is a "DRIVER_IRQL_NOT_LESS_OR_EQUAL" error. I installed MemTest 84 with a CD-ROM and booted it up. The first time it gave me 15 errors. Because I forgot to take a picture of it, I ran the test a second time. Now, I only received three errors and I would like to get some clarification on it and what it means. I have included two photos of the results below.
EDIT: I have also not Overclocked anything.
Here are my specs:
Processor Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
Manufacturer Intel
Speed 2.3 GHz
Number of Cores 8
CPU ID BFEBFBFF000306A9
Family 06
Model 3A
Stepping 9
Revision 15
Video Card 1 Intel(R) HD Graphics 4000
Manufacturer Intel
Chipset Intel(R) HD Graphics 4000
Dedicated Memory 64 MB
Total Memory 1.7 GB
Pixel Shader Version 5.0
Vertex Shader Version 5.0
Hardware T & L Yes
Vendor ID 8086
Device ID 0166
Plug and Play ID VEN_8086&DEV_0166&SUBSYS_181D103C&REV_09
Driver Version 8.15.10.2712
Video Card 2 NVIDIA GeForce GT 650M
Manufacturer NVIDIA
Chipset GeForce GT 650M
Dedicated Memory 2.0 GB
Total Memory 3.9 GB
Hardware T & L Yes
Vendor ID 10DE
Device ID 0FD1
Plug and Play ID VEN_10DE&DEV_0FD1&SUBSYS_181D103C&REV_A1
Driver Version 9.18.13.4709
Memory 16 GB
Operating System Microsoft Windows 7 Home Premium Edition Service Pack 1 (build 7601), 64-bit
Service Pack 1
Size 64 Bit
Edition Home Premium
Version 6.1.7601
Locale 0409
BIOS InsydeH2O Version 03.71.51F.29
Version Insyde F.29
Manufacturer Insyde
Date 10/03/13
Display Maximum Resolution 1600 x 900
Sound Device 1 NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Driver Version
Sound Device 2 IDT High Definition Audio CODEC
Driver Version 6.10.6418.0
Sound Device 3 Intel(R) Display Audio
Driver Version 6.14.0.3090
Sound Device 4 CyberLink WebCam Virtual Driver
Driver Version
DVD hp BD ROM BC-5550H
CD hp BD ROM BC-5550H
Drive 1
Size 909.6 GB
Free 708.7 GB
Drive 2
Size 21.7 GB
Free 2.3 GB
Browsers
Internet Explorer 11.0.9600.17501
Chrome 39.0.2171.99
Firefox
Safari
Software
Java 8.0.250
Flash 11.6.602.180
DirectX 11.0
.NET 3.5.30729.5420
QuickTime
Adobe PDF Reader 10.1.7.27
Here are my MemTest 86 Results:
either it overheats, check with coretemp or hwmonitor (if it does, a cooling pad will help) or the ram or cpu are defective... easiest test would be to replace the ram with one that you know works. if still bad -> cpu if works -> ram.
the fact that it got better after you changed something seems to suggest it's a heating issue.
