Bsod problems
sconeseeker
9
Ive been having many bsods when playing games involving these two files:
hal.dll
ntoskrnl.exe
These are my specs:
Motherboard: Gigabyte GA-MA790XT-UD4P
Graphics Card: ATI Radeon HD 6950
Processor: AMD Phenom(tm) II X4 955 Processor (4 CPUs), ~3.6GHz
Any help would be apriciated.
Thanks, scone.
Does the power supply have two 6-pin PCI-E connectors or does it only have one?
If you're overclocking return all settings back to stock to see if that reduces or eliminates the BSODs.
Have you downloaded and run memtest86+ to determine if any of your memory modules are faulty? Run it through at least one complete cycle of tests. If all of the memory modules are working correctly you should get no error messages in memtest86+.
thanks ill see if i can get this resolved with ther support to :)
