BSOD WHEA_UNCORRECTABLE_ERROR 0x124 HELP !"
Digidox
18
I'm am getting Bsod and the blue screen doesn't show up and just restarts the error code is 124, I tested ram and cpu and gpu and cpu temp is at 60 when doing stress test, all drivers up to date this has been going on for a couple of months and I am sick of this Bsod, and I'm starting to think its the MOBO, And all the parts are on stock clock non are over-clocked. HELP !!!
On Sat 17/01/2015 12:40:30 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011715-20202-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x4B2AEC)
Bugcheck code: 0x124 (0x0, 0xFFFFFA8008734038, 0x0, 0x0)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Specs:
Windows 7 64 bit
Cpu: Fx-8350 4ghz Black vishera edition (Stock cooler)
Gpu: R9 290
Ram: 8GB 1600mhz crucial DDR3
Psu: Corsair CX600 80 plus bronze 600w Power Supply
HDD: 1tb Seagate Barracuda Sata 6Gb/s 64mb Cache
MOBO: Gigabyte 78LMT-USB3
Everything in BIOS is in default setting and im going to boot memtest
