Question BSOD while gaming. Can someone please help I can send event viewer info or whatever can help.
Aug 8, 2021
13
BSOD after 2/3 hrs of gaming tried loads of solutions but none work. The blue screens I'm getting atm is CLOCK WATCHDOG TIMEOUT
Windows 10... i7 8700k.... gefore gtx 1060 6gb....... 16gb ram, I think It's overclocked but I have reset BiOS. Some game (RUST). How do I find temps?
+System
-Provider
[ Name] Microsoft-Windows-WER-SystemErrorReporting
[ Guid] {ABCE23E7-DE45-4366-8631-84FA6C525952}
[ EventSourceName] BugCheck
-EventID1001
[ Qualifiers] 16384
Version0
Level2
Task0
Opcode0
Keywords0x80000000000000
-TimeCreated
[ SystemTime] 2021-08-08T14:43:13.8599325Z
EventRecordID20925
Correlation
-Execution
[ ProcessID] 0
[ ThreadID] 0
ChannelSystem
ComputerDESKTOP-2T04E80
Security
-EventData
param10x00000101 (0x0000000000000010, 0x0000000000000000, 0xffffb101469ea180, 0x0000000000000002)
param2C:\Windows\MEMORY.DMP
param398572852-69ef-42b0-81c4-ff6d3cbfd2ea
+System
-Provider
[ Name]Microsoft-Windows-WER-SystemErrorReporting
[ Guid]{ABCE23E7-DE45-4366-8631-84FA6C525952}
[ EventSourceName]BugCheck
-EventID1001
[ Qualifiers]16384
Version0
Level2
Task0
Opcode0
-TimeCreated
[ SystemTime]2021-08-08T14:43:13.8599325Z
EventRecordID20925
Correlation
-Execution
[ ProcessID]0
[ ThreadID]0
ChannelSystem
Security
-EventData
thats the event viewer from last bsod
CPUID HWMonitor Report
Binaries
HWMonitor version 1.4.4.0
Monitoring
Mainboard Model B360M DS3H (0x0000025A - 0x12E7AE60)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8686
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8686
LPCIO Revision ID 0x3
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 86 86 03 09 00 00 B3 00 00 00 C0 42 C8 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 0A 40 0A 30 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0A40
Hardware Monitors
Hardware monitor ITE IT8686
Voltage 0 0.65 Volts [0x36] (CPU VCORE)
Voltage 1 2.05 Volts [0xAB] (VIN1)
Voltage 2 2.03 Volts [0xA9] (VIN2)
Voltage 3 2.03 Volts [0xA9] (VIN3)
Voltage 5 1.18 Volts [0x62] (VIN5)
Voltage 6 1.26 Volts [0x69] (VIN6)
Voltage 7 1.69 Volts [0x8D] (VIN7)
Voltage 8 1.58 Volts [0x84] (VIN8)
Temperature 0 41 degC (105 degF) [0x29] (TMPIN0)
Temperature 1 39 degC (102 degF) [0x27] (TMPIN1)
Temperature 2 28 degC (82 degF) [0x1C] (TMPIN2)
Temperature 4 34 degC (93 degF) [0x22] (TMPIN4)
Temperature 5 34 degC (93 degF) [0x22] (TMPIN5)
Fan 0 996 RPM [0x2A6] (CPU)
Fan 1 674 RPM [0x3E9] (FANIN1)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 19 10 10 80 FF FF 00 20 FF 98 60 00 00 A4 E9 FF
10 FF FF FF 77 C0 D0 C0 C0 02 03 FF FF FF FF FF FF
20 37 AC A9 A9 00 62 69 8D 84 29 28 1C C9 22 22 80
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 7F 7F 7F 7F 5F 40 AD 6A D4 00 00 00 00 00
50 FF 18 7F 7F 7F 40 00 00 90 5A 1D 12 65 00 00 00
60 00 14 41 46 1C 01 00 00 00 14 3C 46 1C 01 00 FF
70 00 14 3C 46 1C 01 00 3E 00 00 96 00 00 00 0F 98
80 00 00 00 00 FF FF FF FF 02 30 01 02 01 55 E0 89
90 00 00 00 00 FF 10 30 30 40 97 00 00 40 5E C1 00
A0 00 00 96 00 00 0A 0F 98 7F 7F 96 80 00 00 0F 98
B0 C2 2F 7D 6E 7F 00 7F 7F 7F 00 3C 3C 3C 3C 3C 3C
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 01
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor D3D
Hardware monitor NVIDIA NVAPI
Voltage 0 0.69 Volts [0x2B5] (GPU)
Power 0 24.51 pc (GPU)
Temperature 0 54 degC (129 degF) [0x35] (GPU)
Temperature 2 67 degC (152 degF) [0x42] (Hot Spot)
Fan 0 0 RPM [0x0] (GPU #0)
Fan PWM 0 4 pc [0x4] (FANPWMIN0)
Clock Speed 0 1164.00 MHz [0x48C] (Graphics)
Clock Speed 1 4006.80 MHz [0xFA6] (Memory)
Clock Speed 2 n.a. (Processor)
Processors
CPU Groups 1
CPU Group 0 12 CPUs, mask=0xFFF
Number of sockets 1
Number of threads 12
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Thread 1 1
-- Core 1 (ID 1)
-- Thread 2 2
-- Thread 3 3
-- Core 2 (ID 2)
-- Thread 4 4
-- Thread 5 5
-- Core 3 (ID 3)
-- Thread 6 6
-- Thread 7 7
-- Core 4 (ID 4)
-- Thread 8 8
-- Thread 9 9
-- Core 5 (ID 5)
-- Thread 10 10
-- Thread 11 11
Timers
ACPI timer 3.580 MHz
Perf timer 10.000 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 6 (max 6)
Number of threads 12 (max 12)
Manufacturer GenuineIntel
Name Intel Core i7 8700
Codename Coffee Lake
Specification Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz
Package (platform ID) Socket 1151 LGA (0x1)
CPUID 6.E.A
Extended CPUID 6.9E
Core Stepping U0
Technology 14 nm
TDP Limit 65.0 Watts
Tjmax 100.0 °C
Core Speed 798.4 MHz
Multiplier x Bus Speed 8.0 x 99.8 MHz
Base frequency (cores) 99.8 MHz
Base frequency (ext.) 99.8 MHz
Stock frequency 3200 MHz
Max frequency 4600 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3, TSX
Microcode Revision 0xDE
L1 Data cache 6 x 32 KB (8-way, 64-byte line)
L1 Instruction cache 6 x 32 KB (8-way, 64-byte line)
L2 cache 6 x 256 KB (4-way, 64-byte line)
L3 cache 12 MB (16-way, 64-byte line)
Max CPUID level 00000016h
Max CPUID ext. level 80000008h
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 32x
Max turbo ratio 46x
Max efficiency ratio 8x
Speedshift Autonomous
O/C bins none
Ratio 1 core 46x
Ratio 2 cores 45x
Ratio 3 cores 44x
Ratio 4 cores 43x
Ratio 5 cores 43x
Ratio 6 cores 43x
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
TDP Level 65.0 W @ 32x
Temperature 0 38 degC (100 degF) (Package)
Temperature 1 38 degC (100 degF) (Core #0)
Temperature 2 37 degC (98 degF) (Core #1)
Temperature 3 41 degC (105 degF) (Core #2)
Temperature 4 39 degC (102 degF) (Core #3)
Temperature 5 44 degC (111 degF) (Core #4)
Temperature 6 39 degC (102 degF) (Core #5)
Voltage 0 +0.00 Volts (IA Offset)
Voltage 1 +0.00 Volts (GT Offset)
Voltage 2 +0.00 Volts (LLC/Ring Offset)
Voltage 3 +0.00 Volts (System Agent Offset)
Voltage 4 0.64 Volts (VID #0)
Voltage 5 0.64 Volts (VID #1)
Voltage 6 1.14 Volts (VID #2)
Voltage 7 1.15 Volts (VID #3)
Voltage 8 1.14 Volts (VID #4)
Voltage 9 1.14 Volts (VID #5)
Power 00 4.78 W (Package)
Power 01 2.05 W (IA Cores)
Power 02 n.a. (GT)
Power 03 2.73 W (Uncore)
Power 04 n.a. (DRAM)
Clock Speed 0 798.44 MHz (Core #0)
Clock Speed 1 798.44 MHz (Core #1)
Clock Speed 2 4291.62 MHz (Core #2)
Clock Speed 3 4291.62 MHz (Core #3)
Clock Speed 4 4291.62 MHz (Core #4)
Clock Speed 5 4291.62 MHz (Core #5)
Core 0 max ratio 46.0 (effective 43.0)
Core 1 max ratio 46.0 (effective 43.0)
Core 2 max ratio 46.0 (effective 44.0)
Core 3 max ratio 46.0 (effective 44.0)
Core 4 max ratio 46.0 (effective 44.0)
Core 5 max ratio 46.0 (effective 44.0)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 12 MB, 16 thread(s)
CPUID
0x00000000 0x00000016 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000906EA 0x00100800 0x7FFAFBFF 0xBFEBFBFF
0x00000002 0x76036301 0x00F0B5FF 0x00000000 0x00C30000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x00C0003F 0x000003FF 0x00000000
0x00000004 0x1C03C163 0x03C0003F 0x00002FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x11142120
0x00000006 0x000027F7 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x029C6FBF 0x40000000 0x9C002600
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300404 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000000
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x0000001F 0x00000440 0x00000440 0x00000000
0x0000000D 0x0000000F 0x00000440 0x00000100 0x00000000
0x0000000D 0x00000100 0x00000240 0x00000000 0x00000000
0x0000000D 0x00000040 0x000003C0 0x00000000 0x00000000
0x0000000D 0x00000040 0x00000400 0x00000000 0x00000000
0x0000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x00000010 0x00000000 0x00000000 0x00000000 0x00000000
0x00000011 0x00000000 0x00000000 0x00000000 0x00000000
0x00000012 0x00000000 0x00000000 0x00000000 0x00000000
0x00000013 0x00000000 0x00000000 0x00000000 0x00000000
0x00000014 0x00000001 0x0000000F 0x00000007 0x00000000
0x00000015 0x00000002 0x0000010A 0x00000000 0x00000000
0x00000016 0x00000C80 0x000011F8 0x00000064 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000121 0x2C100800
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x37692029 0x3037382D 0x50432030 0x20402055
0x80000004 0x30322E33 0x007A4847 0x00000000 0x00000000
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003027 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00D00
MSR 0x0000003A 0x00000000 0x00020005
MSR 0x00000035 0x00000000 0x0006000C
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x00000770 0x00000000 0x00000001
MSR 0x00000774 0x0000019E 0x54002E01
MSR 0x000000CE 0x08080838 0xF1012000
MSR 0x00000017 0x00040000 0x00000000
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00002B2B 0x2B2C2D2E
MSR 0x00000194 0x00000000 0x00010000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001B1 0x00000000 0x88340800
MSR 0x000001FC 0x00000000 0x0038005F
MSR 0x00000606 0x00000000 0x000A0E03
MSR 0x00000601 0x00000000 0x00000000
MSR 0x00000610 0x0042828A 0x00148208
MSR 0x00000611 0x00000000 0x6D69AAD2
MSR 0x00000639 0x00000000 0x505AA125
MSR 0x00000641 0x00000000 0x00000000
MSR 0x00000619 0x00000000 0x00000000
MSR 0x00000614 0x00000000 0x00000208
MSR 0x00000648 0x00000000 0x00000020
MSR 0x00000649 0x00000000 0x00000000
MSR 0x0000064A 0x00000000 0x00000000
MSR 0x00000198 0x0000237F 0x00002B00
MSR 0x00000199 0x00000000 0x00002000
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
CPUID
0x00000001 0x000906EA 0x01100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000001
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000001
MSR 0x0000001B 0x00000000 0xFEE00C00
MSR 0x000001B1 0x00000000 0x88320800
MSR 0x00000611 0x00000000 0x6D69C229
MSR 0x00000639 0x00000000 0x505AB48F
MSR 0x00000198 0x00002375 0x00002B00
MSR 0x00000199 0x00000000 0x00002E00
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
CPUID
0x00000001 0x000906EA 0x02100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000002
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000002
MSR 0x000001B1 0x00000000 0x88330800
MSR 0x00000611 0x00000000 0x6D69D8EE
MSR 0x00000639 0x00000000 0x505AC78E
MSR 0x00000198 0x00002436 0x00002B00
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 1, Thread ID 1
CPUID
0x00000001 0x000906EA 0x03100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000003
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000003
MSR 0x00000611 0x00000000 0x6D69F05C
MSR 0x00000639 0x00000000 0x505ADAEF
MSR 0x00000198 0x000022DA 0x00002B00
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x000906EA 0x04100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000004
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000004
MSR 0x000001B1 0x00000000 0x88350800
MSR 0x00000611 0x00000000 0x6D6A0AA4
MSR 0x00000639 0x00000000 0x505AF0D9
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 2, Thread ID 1
CPUID
0x00000001 0x000906EA 0x05100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000005
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000005
MSR 0x00000611 0x00000000 0x6D6A1FA7
MSR 0x00000639 0x00000000 0x505B031A
MSR 0x00000198 0x0000236F 0x00002B00
CPU Thread 6
APIC ID 6
Topology Processor ID 0, Core ID 3, Thread ID 0
CPUID
0x00000001 0x000906EA 0x06100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000006
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000006
MSR 0x000001B1 0x00000000 0x88360800
MSR 0x00000611 0x00000000 0x6D6A37A6
MSR 0x00000639 0x00000000 0x505B16BA
MSR 0x00000198 0x00002378 0x00002B00
CPU Thread 7
APIC ID 7
Topology Processor ID 0, Core ID 3, Thread ID 1
CPUID
0x00000001 0x000906EA 0x07100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000007
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000007
MSR 0x00000611 0x00000000 0x6D6A519C
MSR 0x00000639 0x00000000 0x505B2CB4
CPU Thread 8
APIC ID 8
Topology Processor ID 0, Core ID 4, Thread ID 0
CPUID
0x00000001 0x000906EA 0x08100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000008
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000008
MSR 0x00000611 0x00000000 0x6D6A6985
MSR 0x00000639 0x00000000 0x505B4089
CPU Thread 9
APIC ID 9
Topology Processor ID 0, Core ID 4, Thread ID 1
CPUID
0x00000001 0x000906EA 0x09100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000009
0x0000000B 0x00000004 0x0000000C 0x00000201 0x00000009
MSR 0x00000611 0x00000000 0x6D6A7EE6
MSR 0x00000639 0x00000000 0x505B51F4
MSR 0x00000198 0x00002340 0x00002B00
CPU Thread 10
APIC ID 10
Topology Processor ID 0, Core ID 5, Thread ID 0
CPUID
0x00000001 0x000906EA 0x0A100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x0000000A
0x0000000B 0x00000004 0x0000000C 0x00000201 0x0000000A
MSR 0x00000611 0x00000000 0x6D6A9311
MSR 0x00000639 0x00000000 0x505B6335
CPU Thread 11
APIC ID 11
Topology Processor ID 0, Core ID 5, Thread ID 1
CPUID
0x00000001 0x000906EA 0x0B100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x0000000B
0x0000000B 0x00000004 0x0000000C 0x00000201 0x0000000B
MSR 0x00000611 0x00000000 0x6D6AA8AB
MSR 0x00000639 0x00000000 0x505B7495
Storage
Drive 0
Name ST1000VX005-2EZ102
Revision CV11
Serial Z9C7XZAH
Capacity 931.5 GB
Type Fixed
Bus Type SATA (11)
Rotation speed 5900 RPM
Features SMART
Controller Serial ATA Controller - AHCI at bus 0, device 23, function 0
Volume d:\, 931.5 GBytes (79.1 percent available)
Drive 1
Name WDC WDS240G2G0B-00EPW0
Revision UJ450000
Serial 182772800410
Capacity 223.6 GB
Type Fixed, SSD
Bus Type SATA (11)
Features SMART, TRIM
Volume c:\, 223.0 GBytes (64.0 percent available)
USB Devices
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x0451, product=0x2036
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x1038, product=0x1282
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x1038, product=0x1280
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x1532, product=0x0084
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x258A, product=0x1006
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
ID 0x1090304
Name NVIDIA GeForce GTX 1060 6GB
Board Manufacturer ASUSTeK Computer Inc.
Revision A1
Codename GP104
Core family 0x134 (GP104-A)
Cores 1280
ROP Units 48
TM Units 80
RayTracing Cores 0
Tensor Cores 0
Technology 16 nm
Memory type GDDR5 (Hynix)
Memory size 6 GB
Memory bus width 192 bits
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1043)
Model ID 0x1B83 (0x8655)
Revision ID 0xA1
Root device bus 0 (0x0), device 1 (0x1), function 0 (0x0)
Performance Level Base
Core clock 1569.0 MHz
Memory clock 4004.0 MHz
Performance Level Boost
Core clock 1784.5 MHz
Performance Level Current
Core clock 1164.0 MHz
Memory clock 4006.8 MHz
Driver version 30.0.14.7141
WDDM Model 2.7
Monitor 0
Model ZOWIE XL LCD ()
ID BNQ7F45
Serial AAH01174SL0
Manufacturing Date Week 42, Year 2017
Size 27.2 inches
Max Resolution 2560 x 1440 @ 59 Hz
Horizontal Freq. Range 222-222 kHz
Vertical Freq. Range 40-144 Hz
Max Pixel Clock 600 MHz
Gamma Factor 2.2
mod edit - shrunk just to make thread shorter
ACPI
ACPI Tree
Binaries
Monitoring
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8686
Config Mode LDN 0x4
Hardware Monitors
Processors
CPU Groups 1
Number of sockets 1
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Thread 1 1
-- Core 1 (ID 1)
-- Thread 2 2
-- Thread 3 3
-- Core 2 (ID 2)
-- Thread 4 4
-- Thread 5 5
-- Core 3 (ID 3)
-- Thread 6 6
-- Thread 7 7
-- Core 4 (ID 4)
-- Thread 8 8
-- Thread 9 9
-- Core 5 (ID 5)
-- Thread 10 10
-- Thread 11 11
Timers
Sys timer 1.000 KHz
Socket 1 ID = 0
CPUID 6.E.A
Extended CPUID 6.9E
Core Stepping U0
Technology 14 nm
Tjmax 100.0 °C
FID/VID Control yes
Max turbo ratio 46x
O/C bins none
Ratio 1 core 46x
Ratio 2 cores 45x
Ratio 3 cores 44x
Ratio 4 cores 43x
Ratio 5 cores 43x
Ratio 6 cores 43x
Power 02 n.a. (GT)
Thread dumps
CPU Thread 0
APIC ID 0
CPUID
CPU Thread 1
APIC ID 1
CPUID
CPU Thread 2
APIC ID 2
CPUID
CPU Thread 3
APIC ID 3
CPUID
CPU Thread 4
APIC ID 4
CPUID
CPU Thread 5
APIC ID 5
CPUID
CPU Thread 6
APIC ID 6
CPUID
CPU Thread 7
APIC ID 7
CPUID
CPU Thread 8
APIC ID 8
CPUID
CPU Thread 9
APIC ID 9
CPUID
CPU Thread 10
APIC ID 10
CPUID
CPU Thread 11
APIC ID 11
CPUID
Storage
Drive 0
Revision CV11
Serial Z9C7XZAH
Capacity 931.5 GB
Type Fixed
Bus Type SATA (11)
Features SMART
Drive 1
Revision UJ450000
Serial 182772800410
Capacity 223.6 GB
Type Fixed, SSD
Bus Type SATA (11)
USB Devices
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
ID 0x1090304
Revision A1
Codename GP104
Cores 1280
ROP Units 48
TM Units 80
RayTracing Cores 0
Tensor Cores 0
Technology 16 nm
Memory size 6 GB
Revision ID 0xA1
WDDM Model 2.7
Monitor 0
ID BNQ7F45
Serial AAH01174SL0
Size 27.2 inches
Gamma Factor 2.2
ACPI
ACPI Tree
NB Thats the temps with no gaming
IN GAME TEMPS
Binaries
Monitoring
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8686
Config Mode LDN 0x4
Hardware Monitors
Voltage 0 1.14 Volts [0x5F] (CPU VCORE)
Voltage 1 2.03 Volts [0xA9] (VIN1)
Voltage 2 1.94 Volts [0xA2] (VIN2)
Voltage 3 2.02 Volts [0xA8] (VIN3)
Voltage 5 1.15 Volts [0x60] (VIN5)
Temperature 1 40 degC (104 degF) [0x28] (TMPIN1)
Temperature 2 54 degC (129 degF) [0x36] (TMPIN2)
Temperature 4 51 degC (123 degF) [0x33] (TMPIN4)
Temperature 5 43 degC (109 degF) [0x2B] (TMPIN5)
Fan 0 2344 RPM [0x120] (CPU)
Fan 1 618 RPM [0x445] (FANIN1)
00 19 10 10 80 FF FF 00 20 FF 98 60 00 00 21 45 FF
10 FF FF FF 77 C7 D0 C0 C0 01 04 FF FF FF FF FF FF
20 5D A9 A4 A7 00 60 69 8D 84 29 27 36 C9 34 2B 80
80 00 00 00 00 FF FF FF FF 02 30 01 02 01 55 E0 20
90 00 00 00 00 FF 10 30 30 40 97 00 00 40 BD C1 7F
B0 DC 2F 7D 6E 7F 00 7F 7F 7F 00 3C 3C 3C 3C 3C 3C
Voltage 0 1.05 Volts [0x41A] (GPU)
Power 0 67.13 pc (GPU)
Temperature 0 65 degC (149 degF) [0x41] (GPU)
Temperature 2 78 degC (172 degF) [0x4E] (Hot Spot)
Fan 0 1301 RPM [0x515] (GPU #0)
Fan PWM 0 37 pc [0x25] (FANPWMIN0)
Clock Speed 0 1911.00 MHz [0x777] (Graphics)
Processors
CPU Groups 1
Number of sockets 1
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Thread 1 1
-- Core 1 (ID 1)
-- Thread 2 2
-- Thread 3 3
-- Core 2 (ID 2)
-- Thread 4 4
-- Thread 5 5
-- Core 3 (ID 3)
-- Thread 6 6
-- Thread 7 7
-- Core 4 (ID 4)
-- Thread 8 8
-- Thread 9 9
-- Core 5 (ID 5)
-- Thread 10 10
-- Thread 11 11
Timers
Sys timer 1.000 KHz
Socket 1 ID = 0
CPUID 6.E.A
Extended CPUID 6.9E
Core Stepping U0
Technology 14 nm
Tjmax 100.0 °C
Core Speed 4290.5 MHz
Multiplier x Bus Speed 43.0 x 99.8 MHz
FID/VID Control yes
Max turbo ratio 46x
O/C bins none
Ratio 1 core 46x
Ratio 2 cores 45x
Ratio 3 cores 44x
Ratio 4 cores 43x
Ratio 5 cores 43x
Ratio 6 cores 43x
Temperature 0 64 degC (147 degF) (Package)
Temperature 1 60 degC (140 degF) (Core #0)
Temperature 2 65 degC (149 degF) (Core #1)
Temperature 3 63 degC (145 degF) (Core #2)
Temperature 4 59 degC (138 degF) (Core #3)
Temperature 5 58 degC (136 degF) (Core #4)
Temperature 6 61 degC (141 degF) (Core #5)
Voltage 4 1.12 Volts (VID #0)
Voltage 5 1.11 Volts (VID #1)
Voltage 6 1.16 Volts (VID #2)
Voltage 7 1.10 Volts (VID #3)
Voltage 8 1.10 Volts (VID #4)
Power 00 34.65 W (Package)
Power 01 31.67 W (IA Cores)
Power 02 n.a. (GT)
Power 03 2.98 W (Uncore)
Clock Speed 0 4290.54 MHz (Core #0)
Clock Speed 1 4290.54 MHz (Core #1)
Clock Speed 2 4290.54 MHz (Core #2)
Clock Speed 3 4290.54 MHz (Core #3)
Clock Speed 4 4290.54 MHz (Core #4)
Clock Speed 5 4290.54 MHz (Core #5)
Core 2 max ratio 46.0 (effective 43.0)
Core 3 max ratio 46.0 (effective 43.0)
Core 4 max ratio 46.0 (effective 43.0)
Core 5 max ratio 46.0 (effective 43.0)
Thread dumps
CPU Thread 0
APIC ID 0
CPUID
MSR 0x000001B1 0x00000000 0x88210800
MSR 0x00000611 0x00000000 0x10CE39B1
MSR 0x00000639 0x00000000 0x0E17E841
MSR 0x00000198 0x00002284 0x00002B00
CPU Thread 1
APIC ID 1
CPUID
MSR 0x000001B1 0x00000000 0x881E0800
MSR 0x00000611 0x00000000 0x10CE7259
MSR 0x00000639 0x00000000 0x0E181C45
MSR 0x00000198 0x000023FD 0x00002B00
CPU Thread 2
APIC ID 2
CPUID
MSR 0x000001B1 0x00000000 0x881F0800
MSR 0x00000611 0x00000000 0x10CEA9E6
MSR 0x00000639 0x00000000 0x0E185001
MSR 0x00000198 0x000023D9 0x00002B00
CPU Thread 3
APIC ID 3
CPUID
MSR 0x00000611 0x00000000 0x10CEE4B4
MSR 0x00000639 0x00000000 0x0E18869C
MSR 0x00000198 0x000022C2 0x00002B00
CPU Thread 4
APIC ID 4
CPUID
MSR 0x00000611 0x00000000 0x10CF1DDB
MSR 0x00000639 0x00000000 0x0E18BB60
MSR 0x00000198 0x0000239C 0x00002B00
CPU Thread 5
APIC ID 5
CPUID
MSR 0x000001B1 0x00000000 0x88200800
MSR 0x00000611 0x00000000 0x10CF559B
MSR 0x00000639 0x00000000 0x0E18EEC7
MSR 0x00000198 0x000023EA 0x00002B00
CPU Thread 6
APIC ID 6
CPUID
MSR 0x000001B1 0x00000000 0x88220800
MSR 0x00000611 0x00000000 0x10CF8B0B
MSR 0x00000639 0x00000000 0x0E192034
MSR 0x00000198 0x0000247D 0x00002B00
CPU Thread 7
APIC ID 7
CPUID
MSR 0x00000611 0x00000000 0x10CFC629
MSR 0x00000639 0x00000000 0x0E1956F0
MSR 0x00000198 0x000024AB 0x00002B00
CPU Thread 8
APIC ID 8
CPUID
MSR 0x00000611 0x00000000 0x10CFFEFE
MSR 0x00000639 0x00000000 0x0E198B5C
MSR 0x00000198 0x0000247A 0x00002B00
CPU Thread 9
APIC ID 9
CPUID
MSR 0x00000611 0x00000000 0x10D03923
MSR 0x00000639 0x00000000 0x0E19C1BB
MSR 0x00000198 0x0000240D 0x00002B00
CPU Thread 10
APIC ID 10
CPUID
MSR 0x00000611 0x00000000 0x10D0720D
MSR 0x00000639 0x00000000 0x0E19F690
MSR 0x00000198 0x000023EE 0x00002B00
CPU Thread 11
APIC ID 11
CPUID
MSR 0x00000611 0x00000000 0x10D0A93A
MSR 0x00000639 0x00000000 0x0E1A2989
MSR 0x00000198 0x000023C8 0x00002B00
Storage
Drive 0
Revision CV11
Serial Z9C7XZAH
Capacity 931.5 GB
Type Fixed
Bus Type SATA (11)
Features SMART
Drive 1
Revision UJ450000
Serial 182772800410
Capacity 223.6 GB
Type Fixed, SSD
Bus Type SATA (11)
USB Devices
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
ID 0x1090304
Revision A1
Codename GP104
Cores 1280
ROP Units 48
TM Units 80
RayTracing Cores 0
Tensor Cores 0
Technology 16 nm
Memory size 6 GB
Revision ID 0xA1
Core clock 1911.0 MHz
WDDM Model 2.7
Monitor 0
ID BNQ7F45
Serial AAH01174SL0
Size 27.2 inches
Gamma Factor 2.2
ACPI
ACPI Tree
AFTER 1 HOUR OF GAMEPLAY...
Binaries
Monitoring
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8686
Config Mode LDN 0x4
Hardware Monitors
Voltage 0 1.15 Volts [0x60] (CPU VCORE)
Voltage 2 1.97 Volts [0xA4] (VIN2)
Voltage 3 2.00 Volts [0xA7] (VIN3)
Voltage 5 1.14 Volts [0x5F] (VIN5)
Voltage 6 1.25 Volts [0x68] (VIN6)
Temperature 0 45 degC (113 degF) [0x2D] (TMPIN0)
Temperature 1 44 degC (111 degF) [0x2C] (TMPIN1)
Temperature 2 56 degC (132 degF) [0x38] (TMPIN2)
Temperature 4 55 degC (131 degF) [0x37] (TMPIN4)
Temperature 5 48 degC (118 degF) [0x30] (TMPIN5)
Fan 0 2455 RPM [0x113] (CPU)
Fan 1 720 RPM [0x3AA] (FANIN1)
00 19 10 10 80 FF FF 00 20 FF 98 60 00 00 15 A9 FF
10 FF FF FF 77 C7 D0 C0 C0 01 03 FF FF FF FF FF FF
20 5F A9 A2 A7 00 60 69 8D 84 2D 2C 38 C9 37 30 80
80 00 00 00 00 FF FF FF FF 02 30 01 02 01 55 E0 9D
90 00 00 00 00 FF 10 30 30 40 97 00 00 40 29 C1 E2
B0 DE 2F 7D 6E 7F 00 7F 7F 7F 00 3C 3C 3C 3C 3C 3C
Voltage 0 1.04 Volts [0x413] (GPU)
Power 0 64.32 pc (GPU)
Fan 0 1350 RPM [0x546] (GPU #0)
Fan PWM 0 38 pc [0x26] (FANPWMIN0)
Clock Speed 0 1898.00 MHz [0x76A] (Graphics)
Processors
CPU Groups 1
Number of sockets 1
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Thread 1 1
-- Core 1 (ID 1)
-- Thread 2 2
-- Thread 3 3
-- Core 2 (ID 2)
-- Thread 4 4
-- Thread 5 5
-- Core 3 (ID 3)
-- Thread 6 6
-- Thread 7 7
-- Core 4 (ID 4)
-- Thread 8 8
-- Thread 9 9
-- Core 5 (ID 5)
-- Thread 10 10
-- Thread 11 11
Timers
Sys timer 1.000 KHz
Socket 1 ID = 0
CPUID 6.E.A
Extended CPUID 6.9E
Core Stepping U0
Technology 14 nm
Tjmax 100.0 °C
Core Speed 4288.4 MHz
Multiplier x Bus Speed 43.0 x 99.7 MHz
Base frequency (cores) 99.7 MHz
Base frequency (ext.) 99.7 MHz
FID/VID Control yes
Max turbo ratio 46x
O/C bins none
Ratio 1 core 46x
Ratio 2 cores 45x
Ratio 3 cores 44x
Ratio 4 cores 43x
Ratio 5 cores 43x
Ratio 6 cores 43x
Temperature 0 65 degC (149 degF) (Package)
Temperature 1 62 degC (143 degF) (Core #0)
Temperature 2 66 degC (150 degF) (Core #1)
Temperature 4 65 degC (149 degF) (Core #3)
Temperature 5 61 degC (141 degF) (Core #4)
Voltage 4 1.11 Volts (VID #0)
Voltage 5 1.15 Volts (VID #1)
Voltage 8 1.15 Volts (VID #4)
Voltage 9 1.12 Volts (VID #5)
Power 00 34.09 W (Package)
Power 01 31.18 W (IA Cores)
Power 02 n.a. (GT)
Power 03 2.91 W (Uncore)
Clock Speed 0 4288.43 MHz (Core #0)
Clock Speed 1 4288.43 MHz (Core #1)
Clock Speed 2 4288.43 MHz (Core #2)
Clock Speed 3 4288.43 MHz (Core #3)
Clock Speed 4 4288.43 MHz (Core #4)
Clock Speed 5 4288.43 MHz (Core #5)
Thread dumps
CPU Thread 0
APIC ID 0
CPUID
MSR 0x000001B1 0x00000000 0x881B0800
MSR 0x00000611 0x00000000 0x5C348B37
MSR 0x00000639 0x00000000 0x531381AF
MSR 0x00000198 0x00002455 0x00002B00
CPU Thread 1
APIC ID 1
CPUID
MSR 0x000001B1 0x00000000 0x881D0800
MSR 0x00000611 0x00000000 0x5C34C671
MSR 0x00000639 0x00000000 0x5313B8C3
MSR 0x00000198 0x00002438 0x00002B00
CPU Thread 2
APIC ID 2
CPUID
MSR 0x00000611 0x00000000 0x5C3500B0
MSR 0x00000639 0x00000000 0x5313EE6A
MSR 0x00000198 0x0000233B 0x00002B00
CPU Thread 3
APIC ID 3
CPUID
MSR 0x00000611 0x00000000 0x5C3538F9
MSR 0x00000639 0x00000000 0x531422BF
CPU Thread 4
APIC ID 4
CPUID
MSR 0x00000611 0x00000000 0x5C356FEE
MSR 0x00000639 0x00000000 0x53145711
MSR 0x00000198 0x0000236E 0x00002B00
CPU Thread 5
APIC ID 5
CPUID
MSR 0x00000611 0x00000000 0x5C35AF19
MSR 0x00000639 0x00000000 0x531490AE
MSR 0x00000198 0x000024BC 0x00002B00
CPU Thread 6
APIC ID 6
CPUID
MSR 0x00000611 0x00000000 0x5C35E960
MSR 0x00000639 0x00000000 0x5314C6EF
MSR 0x00000198 0x000023DC 0x00002B00
CPU Thread 7
APIC ID 7
CPUID
MSR 0x00000611 0x00000000 0x5C361F18
MSR 0x00000639 0x00000000 0x5314F8BD
MSR 0x00000198 0x0000238F 0x00002B00
CPU Thread 8
APIC ID 8
CPUID
MSR 0x00000611 0x00000000 0x5C365932
MSR 0x00000639 0x00000000 0x53152DAF
MSR 0x00000198 0x000024D6 0x00002B00
CPU Thread 9
APIC ID 9
CPUID
MSR 0x00000611 0x00000000 0x5C369207
MSR 0x00000639 0x00000000 0x5315627F
MSR 0x00000198 0x0000243F 0x00002B00
CPU Thread 10
APIC ID 10
CPUID
MSR 0x00000611 0x00000000 0x5C36CB4A
MSR 0x00000639 0x00000000 0x53159808
MSR 0x00000198 0x00002411 0x00002B00
CPU Thread 11
APIC ID 11
CPUID
MSR 0x00000611 0x00000000 0x5C37054A
MSR 0x00000639 0x00000000 0x5315CDC7
MSR 0x00000198 0x0000241C 0x00002B00
Storage
Drive 0
Revision CV11
Serial Z9C7XZAH
Capacity 931.5 GB
Type Fixed
Bus Type SATA (11)
Features SMART
Drive 1
Revision UJ450000
Serial 182772800410
Capacity 223.6 GB
Type Fixed, SSD
Bus Type SATA (11)
USB Devices
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
ID 0x1090304
Revision A1
Codename GP104
Cores 1280
ROP Units 48
TM Units 80
RayTracing Cores 0
Tensor Cores 0
Technology 16 nm
Memory size 6 GB
Revision ID 0xA1
Core clock 1898.0 MHz
WDDM Model 2.7
Monitor 0
ID BNQ7F45
Serial AAH01174SL0
Size 27.2 inches
Gamma Factor 2.2
ACPI
ACPI Tree
i added spoilers as its just too long
Can you follow option one on the following link - here - and then do this step below: Small memory dumps - Have Windows Create a Small Memory Dump (Minidump) on BSOD - that creates a file in c windows/minidump after the next BSOD
  1. Open Windows File Explore
  2. Navigate to C:\Windows\Minidump
  3. Copy the mini-dump files out onto your Desktop
  4. Do not use Winzip, use the built in facility in Windows
  5. Select those files on your Desktop, right click them and choose 'Send to' - Compressed (zipped) folder
  6. Upload the zip file to the Cloud (OneDrive, DropBox . . . etc.)
  7. Then post a link here to the zip file, so we can take a look for you . . .
Reactions: 4745454b
I'm seeing temps around 65C, so I'm not sure what's wrong. Issues after a time to me is heat. But as least from the info provided your CPU temps are fine. It could be an issue with the board or GPU temps. You might want to start looking at voltage and ram. That would be my next guess.
