BSOD WITH Bccode 34, Bccode 3b,Bccode c2, Bccode 19, Bccode 7e, Bccode 1e
majharul
My PC facing trouble from frequent Blue Screen error. different type of code are arrived (Bccode C2, Bccode 3b, Bccode 19, Bccode 34, Bccode 19, Bccode 7e,) when I shut down my PC, But not every shutdown. After full system update by windows update and verify from manufacturer website, after 3 days again Bccode 1e appear.
Now I Uninstall newly installed 2RAMs of 4installed RAMs. Place remain 2 rams in a1 and b1 slot. After 1 day Bccode 34 appear again.
Memtest86+ (7th pass) and Hard Disk check (Chkdsk) shows RAM and Hard Disk is Ok. Please Help me. I have upload minidump files , sfc /scannow and other reports http://sdrv.ms/ZByTrL
I read many review, they examine dump files and get the point.
Please help me
PC Configuration:
PROCESSOR - AMD PHENOM 2 X6 1090T,
MOBO - ASUS M5AFX99 PRO R2,
RAM - 4X4GB ZEON HMT351U6AFR8C-H9,
GPU - SPARKLE nVIDIA GeForce GT 520,
HDD - SEAGATE ST31000524AS,
PSU - COOLERMASTER GX 550W
OS - Windows 7 Ultimate 64 Bit
Antivirus - Quick Heal Total Security 2013
skmajharulislam
From what i can see, your errors is caused by Quick Heal AntiVirus(Wstif.sys) One is caused by your driver (svchost.exe) This could be a virus but cant be sure. More than likely driver related.
you have one that is a Pool corruption, This is caused by corrupt data and or registry leaks which i'm going to say is caused by Quick Heal AntiVirus.
I suggest you try updating your drivers and completely removing Quick Heal AntiVirus. if memtest is not showing any problems then its definitely corrupt drivers and a registry leak and maybe even a virus.
Use this: Quick Heal Removal Tool ,to get rid of Quick Heal. Or do it manually.
