As the title says, I have been getting at least one bsod restart, while in the middle of playing seemingly any given game I have. DOOM, Battlefield 1, The Witcher 3, Grand Theft Auto 5
The bsod messages I have been getting for the most part, are pretty similar to each other: DRIVER_IRQL_NOT_LESS_OR_EQUAL, SYSTEM_SERVICE_EXCEPTION, DRIVER_OVERRAN_STACK_BUFFER, IRQL_NOT_LESS_OR_EQUAL
Here are the most recent dump files from top to bottom: (From BlueScreenView)
http://www.mediafire.com/file/oe58i1vev4ufcap/022017-41...
http://www.mediafire.com/file/mj4n9a4k2vxk40w/022017-35...
http://www.mediafire.com/file/tnrgc7l1lrstbyb/021917-36...
http://www.mediafire.com/file/0kcjp9lh8jioaf2/021617-36...
http://www.mediafire.com/file/xtj807egksf2iod/021317-37...
http://www.mediafire.com/file/tea2hhl4rc4veh9/021317-36...
Here is the part/spec list of my build: (Intended use is to do schoolwork, and also a good bit of gamming. Potentially even streaming if I can fix the random bsod's)
https://pcpartpicker.com/user/Samwise_Gamgee/saved/TbNQ7P
Windows is installed on one of the 500gb SSD's.
It should be known that I have already virtually replaced my whole pc in trying to troubleshoot specific parts. And I troubleshooted the parts I replaced before doing so, just went with my gut feelings.
Parts I have replaced: Motherboard, RAM, PSU, GPU, CPU Cooler (PC Part picker has my current parts)
I recently went into computer management and checked window's errors logs. This is what I found; Critical Level Kernel-Power 41...
Again I have already replaced most of my hardware, should I just try inspecting all of the connections and reseating them?
Things I've done:
-CMD chkdsk, it passed (For the HDD)
-Uninstalled and Updated Drivers
-Flashed to the latest bios from my mobo manufacturers webpage, problem persists
-Use MemTest on a flash drive to test each individual stick for 8 passes, both passed (I actually haven't done this on the new sticks of RAM because I haven't considered that they are the trouble causers. Replaced the RAM mainly because it was a package with the old motherboard.)
-Scanned for malware or viruses, all clean.
-Ran the CPU under a 12 hour stress test with Prime95 to ensure stability, all cores passed.
-Restored windows to a previous point, still get blue screens in games.
-Completely reformatted my SSD with Windows and reinstalled the whole OS, still here with the same problem.
Extra info that may or may not be useful:
-My HDD is basically my bulk storage drive. I Have all of my downloads, music, documents, programs that don't need to run fast, and pictures going in there. I noticed that without my side panel on, it makes a decent high pitched buzzing noise. Although it passed the basic windows chkdsk scan, I still am slightly worried its causing problems.
Things I've done:
