Question bubble mailer and clam shell case enough for cpu shipping
Spankymcbob1
273
Trying to figure out if a bubble mailer with some cardboard inserts along with a clam shell case for the cpu is enough to safely ship and amd cpu. I think the one that I have has some anti static foam where you put the cpu down.
if you don't have the original box it came, some people use a soft foam to pu the cpu overt it, then the bubblewrap and the box
the problem is that if the foam is not soft enough, it will bent some pins
sometimes is simpler to send the cpu on a mainboard, no bent pins this way, even a dead mainboard will provide the pins protection the cpu needs
