[SOLVED] Budget £1150 PC Animators Build !! NEED HELP !!
Jun 21, 2021
5
Hey experts!
As the title says, I have a brand new budget to help me build a PC System that will help me in my line of work. I have just graduated and now am in the market for a build that will benefit me for a few years!
I asked on here before but my budget was a little lower and I wanted to hold out a lil while going off of the advice given and now have increased my budget to hopefully add a bit more room for improvement!
So again Budget £1150 (specific I know)
And many thanks in advance for anyone that is willing to lend me some expert help!
You can cut the price of this build by going with a GTX 1650.
https://www.ebuyer.com/801778-fract...nt-computer-case-with-window-fd-ca-focus-bk-w
Fractal Design Focus G - Mid Tower Computer Case £44.49
Exhaust fan for that case.
https://www.scan.co.uk/products/120...0rpm-563cfm-fluid-dynamic-bearing-black-4-pin
Arctic P12 PWM 120mm 4-Pin Case Fan £3.98
https://www.ebuyer.com/782056-corsair-tx550m-550w-80-plus-gold-power-supply-cp-9020133-uk
Corsair TX550M 550W 80+ Gold Semi Modular Power Supply £59.98
https://www.scan.co.uk/products/asr...ta3-pcie-40-2x-m2-gbe-usb-32-gen1-a-micro-atx
ASRock B660M PRO RS...
ASRock B660M PRO RS £114.98
https://www.scan.co.uk/products/04-...-threads-21ghz-49ghz-turbo-25mb-cache-65w-ret
Intel Core i7 12700F £339.98
https://www.scan.co.uk/products/arc...r-aluminium-fins-4x-direct-touch-copper-heatp
Arctic Freezer 34 eSports CPU Cooler £29.99
https://www.arctic.de/us/LGA1700-Mounting-Kit-Freezer-34-black/MPSAS00892A
LGA1700 Mounting Kit - Freezer 34
https://www.ebuyer.com/1265629-king...-16gb-3200mhz-ddr4-ram-black-kf432c16bb1k2-32
Kingston FURY Beast 32GB (2x16GB) DDR4 3200MHz CL16 £112.98
https://www.ebuyer.com/947319-wd-blue-sn550-1tb-nvme-m-2-2280-pcie-gen3-ssd-wds100t2b0c
WD Blue SN550 1TB NVME M.2 2280 PCIe Gen3 SSD £67.90
https://www.amazon.co.uk/dp/B081SPGMBD
ASUS TUF Gaming GeForce GTX 1660 Super OC 6GB DDR6 £399.99
Total: £1175 inc VAT
https://www.asrock.com/mb/Intel/B660M Pro RS/index.asp
View: https://www.youtube.com/watch?v=ydgN4W97Esk
Reactions: Flayed
