Budget Cpu fan for i5-6600
KrisG025
52
Hello , i am searching for budget ,but good cpu fan for i5-6600 . The stock cooler isnt good enough when i play pubg the cpu gets pretty hot 65C+ , gonna use Arctic Mx4 with it.
http://www.antec.com/product.php?id=707200&pid=59&lan=nz what do you think about this one .
^+1 yeah, it's not very hot. It's also not as if you can OC that chip. The stock cooler is designed to manage the temps perfectly. Don't be worrying. Just applying thermal paste anew will prob reduce the temps by 5c. Don't waste the money on a new cooler.
I noticed that , when it gets to 71 C spikes laggs for a second . Are you sure that only the thermal paste could make 65C limit .
well thermal paste replacing is required maybe once a year or maybe every second year. Best to keep up good practice with it, as it degrades over time (and obviously with increase heat). New thermal paste applicaiton, generally brings the temps down by about 5c. Some higher quality paste will reduce it even more.
I suppose the point is, that buying a new cooler isn't required. Just re-apply the paste. There are some very easy to follow guides on doing it.
This is a good guide : https://www.youtube.com/watch?v=SST61g3hnIs
I was using the paste that came with intel stock cpu , now when i apply the Arctic Mx4 it will be better i guess 😀
yes, it will be better :)
