Budget friendly wifi audio adapter for receivers
LudinK
81
So we have stereo system built into our house and I’ve usually been using a 15 feet rca to 3.5mm wire for the input to the receiver however you guys probably already know the struggles of a wired connection so I wanted to go wireless. The most common right now are Bluetooth adapters like the Logitech one however I’m pretty sure the range isn’t that great with Bluetooth. Our house is around 6000 square feet and Bluetooth will definitely not be able to cover even a small portion of that, hence why I’m searching for a wifi one since we already have proper wifi set up all around the house. I’ve had no luck with google search as I get really weird products or expensive ones. Are there any quality wifi adapters under the 75$ range?
