Budget PC Water Cooling Questions
bryson04
49
So I'm Planning on buying a FX-8320 and I Want to over clock it to 4.0GHz and then after i reach that point i want to remain there. I'm Wondering how much CPU- Life span that will remove, what I need about cooling, and is there anything i need to check with my other bits of hardware to make sure its compatible. I appreciate it, but I am also on a tight budget, and trying to stay under $500 dollars with my build, in which I've already spent: $81.93 USD on motherboard, $56.54 USD on Chassis, and at most i will be paying $78.41 USD on RAM which puts me at 216.88. I need a PSU, GPU, and CPU
UPDATE- I can and most likely will purchase from ebay
275** dollars though. haha... I have to limit you people somewhere or next thing i know i will be out a thousand bucks. LOL :no: 😀 Its just a number that i am testing this community with to see if they can achieve a question that is deeply important to me
Try using this site for pricing and compatibility:
http://pcpartpicker.com/
The FX-8320 is around 130usd so that will leave you around 80usd for PSU and GPU. I don't think you will have to worry about shortening the lifespan of the CPU if all you want is 4ghz, the max turbo speed is 4ghz.
A good air cooler can at least as good as a closed loop watercooler, and somewhat cheaper. Good luck.
okay thanks!!
Ladies and Gentlemen, please turn your heads over to Mr. O'Keefe. Solves two of my problems that I've posted on here with-in 24 hours. Thanks very much!!!!!!!!!!!!
