budget sound card 7.1 with optical digital out
Daniel Harvey
175
Hi
im looking for a sound card, so that i can use my av receiver (onkyo TX-SR506) with my PC.
i have the Xonar DGX installed right now, however it is fairly old and as far as im aware it doesnt support 5.1 or 7.1. at least i cant get it to
so the only requirements are that it has to have an optical out and support at least 5.1, but ideally 7.1.
Also im not sure what it is called, but ive read that some sound cards can split non-surround sounds into surround. that sounds like a great feature if it were to work.
finally, some of you may ask
why don't i just use hdmi from my gpu to the receiver?
well, i have tried to this before, and i cannot get it even to pass sound or picture through the receiver
my pc specs should be in my signature
thanks in advance
hi, thanks for the reply
i would certainly be going for a card around the 'even cheaper' option
the reason to buy a new one is because i need an optical digital output, which my motherboard doesn't have
ill try using the hd graphics' hdmi for the passthrough, however i believe my particular receiver is faulty as this feature has never worked
ive never heard of NVIDIA(R) Optimus however a quick google search suggests its just for notebooks?
haha, i think ill leave it then 😛
I only wanted advice on a sound card, yet suddenly we are talking about graphics cards 😛
