Budget video build - down to case and ps - help
husker92
41
OK, I finally got my components finalized, I am just stuck on the case and power supply.
Here is what I have so far:
AMD 7750 - http://www.microcenter.com/single_product_results.phtml?product_id=0306467
ASRock N61P-S - http://www.newegg.com/Product/Product.aspx?Item=N82E16813157147
OCz DDR2 800 4gb - http://www.newegg.com/Product/Product.aspx?Item=N82E16820227199&Tpk=ocz2g8004gk
WD green 640GB - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136298
Samsung DVD - http://www.newegg.com/Product/Product.aspx?Item=N82E16827151173
I already have Vista 64B Ultimate ready to go.
I was thinking of using this case/ps combo since I am not a gamer and won't have an add on graphics card. Will this work for my set up?
http://www.microcenter.com/single_product_results.phtml?product_id=0232427?
If not, are there any microcenter power supplies that would not be considered junk (and would not cost too much)?
Sorry, I couldn't get your psu/case link to work but if I was you I'd get something like this:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.176612
I wouldn't trust a Microcenter psu but I'm not familiar with them. The absolute last thing you want to be cheap on is the psu so do yourself a favor and get a reputable brand name.
Also, I'd spend an extra 22 bucks and get this mobo which actually is in a combo deal with the processor you're looking at.
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.172804
