Build 1 vs Build 2
an i7 isnt needed for gaming, the i5is more than enough, and you dont need 2133MHz ram, get a low profile 1600 or 1866 MHz kit (low profile because the NH-D14 is huge)
I will be streaming as well, will an i5 be efficient still? Also do you have a link to the RAM you prefer?
Edit* Also would it be better to get the i5 and 2 970 with sli for the same price or just buy the 980 with the i5?
I guess my main question is should I just 970 sli with i7 or i5 with 980?
