Approximate Purchase | This month |
Budget Range | $750 Before Rebates |
System Usage from Most to Least Important | Programming, Virtualing, Basic graphic editing |
Are you buying a monitor | No |
Do you need to buy OS | No |
Preferred Website(s) for Parts | newegg.com |
Location | Indonesia |
Parts Preferences | Intel CPU |
Overclocking | Maybe |
SLI or Crossfire | No (Just integrated GPU, no need dedicated GPU) |
Your Monitor Resolution | 1920x1080 |
Additional Comments | I know some will say "you just need Raspberry PI for programming" but that is not my case, I need fully loaded computer that can handle opening Visual Studio, Android Studio, and/or VS Code, and sometimes SQL Server Management Studio, and/or Adobe Photoshop or Adobe Illustrator while running 1 to 3 different browser with ~20 total tabs opened and 1 VM is booted in the background. If you wondering why I need to open all of that, in my office I'am an [Android, IOS, Windows, Web] beginner Programmer that do all the stuff my self. |
Here are the parts that I have planned to buy:
- Intel Core i7-8700K (Do not know if this is overkill, maybe i5-8400 is sufficient)
- Gigabyte Z390 UD
- Ballistix Sport AT 32GB (2 x 16GB)
- Samsung V-NAND SSD 960 EVO NVMe M.2 250GB
- CORSAIR Series CX550M
- CPU Cooler Arctic Cooling Freezer 7 Pro Rev.2
