Build a Oil Cooled pc help?
accesgranted1
222
hi guys i want to know if i can build a oil cooled pc with cooking or sunflower oil
and if i can just fill up a tank with sun or cookin oil get the HDD outside and just boot it up normally.
i heard that you need to remove all fans or its fake
and what would be the result because my GPU is going 100+C and i think it will burn to death 😀
so?
thanks in advance
p.s Sorry for Bad English lol
No.
You can't use organic oils. First, I'm not sure if they are non conductive, and second they get rancid. You need to use mineral oil.
I'm not sure what you mean by 'remove all fans or its fake', so if you could clarify that.
Also, is there a particular reason you're trying to do this, or just looking for a project?
No.
