Build a system - $3K
Immaculate
1,450
I will be buying parts on Black Friday/Cyber Monday.
Could you put me together a PC around the 3K budget? Less is better.
I would be needing everything, OS, monitor, K/M, headphones. I would like to go 1440p. 2-way SLI at most. NO 3-way GPU configurations please.
Unless your are flexible in the hardware you use, Black Friday/Cyber Monday doesnt amount to much. Also, putting together a rig today that you arent going to buy for 6-8 weeks, or even have a clue what will be on sale then, is probably not a good idea.
Flexible in the hardware I use? I was planning on an i7 from Microcenter. 4770K was $250 last year. I was considering the 5820K if they drop it then from the $300 mark its at.
Just ignore the BF/CM thing then and put together a $3k or so build and I will adjust it in the coming weeks if new hardware comes or if there is a better deal on something very similar.
