Question Build advice and compatibility
kerangovender
Commendable
Nov 26, 2017
228
19
1,595
4
Hello everyone
I am looking to build a pc and i have chosen
Mobo : MSI X570 A PRO
CPU : AMD RYZEN 5 2400G
RAM : 1 x 8Gb kingston ddr4 2666mhz
Other parts not listed...
Would an EVGA G5 650W psu be ok as it doesn't have a 4 pin connector but this is on the mobo. It is used to supply additional power for overclocking etc. Would the CPU still overclock automatically?
I don't intend on getting a gpu yet as I'm not really doing gaming right now. I will also upgrade some parts and get more ram later
Okay so you have gone a little bit over. I would save some money and move to a B450 motherboard. Unless you will be upgrading to a Ryzen 3000 series CPU later, then stick to the X570 motherboard .As to the power supply that is a lot of power for what you need. Also try to go for DDR 4 3200 and at least 16gb in 2 x 5GB sticks as Ryzen will make use of it and it is now fairly cost effective.
Might need a BIOS update as I cannot find a Ryzen 2400G. Check box to see Ryzen 3000 ready!
PCPartPicker Part List: https://pcpartpicker.com/list/DL4FGc
CPU: AMD Ryzen 3 3200G 3.6 GHz Quad-Core Processor ($87.00 @ Amazon)
Motherboard: ASRock B450 Steel Legend ATX AM4 Motherboard ($79.99 @ Newegg)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 Memory ($72.98 @ Amazon)
Power Supply: EVGA SuperNOVA G3 550 W 80+ Gold Certified Fully Modular ATX Power Supply ($81.98 @ Newegg)
Total: $321.95
Generated by PCPartPicker 2019-11-15 14:16 EST-0500
X570 route and no BIOS update issues.
PCPartPicker Part List: https://pcpartpicker.com/list/zQfsk6
CPU: AMD Ryzen 5 3400G 3.7 GHz Quad-Core Processor ($130.00 @ Amazon)
Motherboard: ASRock X570 Phantom Gaming 4 ATX AM4 Motherboard ($114.99 @ Newegg)
Total: $399.95
Generated by PCPartPicker 2019-11-15 14:21 EST-0500
