[SOLVED] Build advice for £500-£600 budget
May 21, 2020
29
Hi I’m looking to build a pc doesn’t matter if it’s used eBay parts for £500-600. I wanna be able to run cod Warzone etc. This budget doesn’t need to include monitor, keyboard, mouse etc.
Wanted to put a better gpu in there but with the current gpu situation its hard to find a gpu for a reasonable price.
https://uk.pcpartpicker.com/list/mPf6mk
Warzone is a BR so its more cpu dependant than gpu,and with 16gb,you should be getting 100fps at competitive settings
My take on your list, save £50 on the case and a better PSU:
PCPartPicker Part List
CPU: Intel Core i3-10100F 3.6 GHz Quad-Core Processor (£78.67 @ Scan.co.uk)
Motherboard: MSI H410M-A PRO Micro ATX LGA1200 Motherboard (£62.99 @ Ebuyer)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (£79.98 @ Aria PC)
Storage: Samsung 860 Evo 250 GB 2.5" Solid State Drive (£37.98 @ Aria PC)
Storage: Seagate BarraCuda 1 TB 3.5" 7200RPM Internal Hard Drive (£36.48 @ Aria PC)
Video Card: MSI GeForce GTX 1050 Ti 4 GB GAMING X Video Card (£159.99 @ CCL Computers)
Case: Fractal Design Focus G Mini MicroATX Mini Tower Case (£43.98 @ Amazon UK)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply (£69.95 @ Amazon UK)
Total: £570.02
Generated by PCPartPicker 2021-01-18 23:54 GMT+0000
Reactions: Why_Me and Djoza
Total: £570.02
Bruh i was legit debating 5 minutes if i should put that case or the p300A,then i thought OP probably doesnt like thoose 'old design' cases as much as me,so i put a p300A in there.
Total: £570.02
Nice build. I don't believe though that the H410 boards support 3200MHz RAM.
You could so something such as this while keeping the cost down. Size up on the SSD while doing away with the mechanical HD,
https://www.box.co.uk/HyperX-FURY-16GB-(2x-8GB)-2666MHz-DDR4-R_2716319.html
HYPERX FURY 16GB (2X 8GB) 2666MHZ CL16 DDR4 RAM £64.07
https://www.ebuyer.com/912502-adata-su630-960gb-2-5-ssd-asu630ss-960gq-r
ADATA SU630 960GB 2.5" SSD £79.98
I believe these h410 mobo's support up to 2933mhz i think.I just put it there cuz idk its one of the good cheapest ram out there.There is also patriot viper
Reactions: Why_Me
Do you think the almighty 240gb ssd and 1 tb hdd combo is finally gone?
I see people use 1tb ssd's more and more often than ssd/hdd combo.At least the budget ones do.
The 2.5" 1 TB SSD's are so cheap now that a 1TB mechanical HD is a thing of the past imo. A lot easier and uses less wattage to go with a single SSD. There's multiple 1TB SSD's now for under $90 USD. It's the only components going down in price tmk.
Reactions: Djoza
