Hello,
I am looking for advice and recommendations on parts for a new PC I am planning on building next month. I have a decent budget and I am less concerned with cutting corners and more concerned about getting the best performance out of my system. That being said, I would like to avoid burning money for no reason, so I am trying to avoid the absolute bleeding edge tech that comes with a ridiculous price tag.
This computer will be used primarily for rendering, video editing, CAD, benchmarking, and other resource intensive software. I except to see high demand on the CPU, RAM, and SSD specifically. In regards to the video card, I would like to stick with the Quadro series because it is certified specifically for my software, but I am open to other suggestions here as well.
Approximate Purchase Date: Soon (Next month)
Budget Range: $2,700 max
System Usage from Most to Least Important: Rendering, Drafting (CAD), Video Editing, Benchmarking, Power User
Are you buying a monitor: No
Parts to Upgrade: Building from scratch
Do you need to buy OS: Yes
Preferred Website(s) for Parts: Newegg
Parts Preferences: Intel / Asus
Overclocking: Probably
SLI or Crossfire: No
Your Monitor Resolution: 1920x1080
Additional Comments: Looking for the best possible performance without paying through the nose for truly bleeding edge tech.
And Most Importantly, Why Are You Upgrading: Its time.
Parts I am currently considering:
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=32656107
NVIDIA® Quadro® K2000 VCQK2000-PB 2GB GDDR5 PCI Express 2.0 x16 Workstation Video Card
ASUS X99-A LGA 2011-v3 Intel X99 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
G.SKILL Ripjaws 4 series 64GB (8 x 8GB) 288-Pin DDR4 SDRAM DDR4 2800 (PC4-22400) Intel X99 Desktop Memory Model F4-2800C15Q2-64GRK
Crucial MX100 CT512MX100SSD1 2.5" 512GB SATA III MLC Internal Solid State Drive (SSD)
Thermaltake TR2 TR-700 700W ATX 12V V2.3 & EPS 12V SLI Ready CrossFire Ready Active PFC Thermaltake TR-700 Power Supply
Intel Core i7-5820K Haswell-E 6-Core 3.3GHz LGA 2011-v3 140W Desktop Processor BX80648I75820K
Intel Thermal Solution Air BXTS13A Cooling Fan & Heatsink LGA2011
Logitech MK120 Black USB Wired Slim Desktop
ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 8X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
Microsoft Windows 8.1 Pro - 64-bit - OEM
Western Digital Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive - OEM
Corsair Carbide Series 200R Black Steel structure with molded ABS plastic accent pieces ATX Mid Tower Computer Case
