Build advice for heavy gaming / 3d printing.
WhiteFigs
12
Hi,
Reason: I'm looking at upgrading my rig. 1) i'm having issues with my memory/mobo/cpu conflicting when OC'n my memory, mostly due to my cpu bottle necking my ram at 1600 freq. 2) the CPU and Mobo are out-dated. 3) adding a third graphics card which does not fit on my mobo.
Use: I do heavy gaming on dual 1440p monitors (when work allows), mild 3d design, and run two 3d printers off my rig.
Current rig: listed below, the cpu is water-cooled with 360 radiator.
Operating System
Windows 10 Pro 64-bit
CPU
Intel Core i7 3930K @ 3.20GHz 36 °C
Sandy Bridge-E 32nm Technology
RAM
32.0GB DDR3 @ 799MHz (9-9-9-24)
Motherboard
ASUSTeK COMPUTER INC. RAMPAGE IV EXTREME (LGA2011) 35 °C
Graphics
ASUS PB278 (2560x1440@59Hz)
4095MB NVIDIA GeForce GTX 970 (MSI) 31 °C
ForceWare version: 358.91
SLI Enabled
Storage
931GB Samsung SSD 850 EVO 1TB (SSD) 32 °C
2794GB Hitachi HDS723030ALA640 (SATA) 33 °C
465GB ASMT 2115 USB Device (SSD) 32 °C
14GB SanDisk SanDisk Ultra USB Device (USB)
Optical Drives
ASUS DRW-24D3ST
Audio
Realtek High Definition Audio
BELOW IS WHAT I WISH TO UPGRADE. Opinions on the mobo / cpu / memory? anything better which is not a massive blow to the wallet? Appreciate the help
Operating System
CPU
Intel Core i7 5820K Haswell-E 6-Core LGA 2011-3 3.3GHz CPU
RAM
Kingston HyperX Fury 32GB (4x8GB) DDR4 Black
Motherboard
MSI X99A Gaming 7 USB 3.1 Socket 2011-V3 ATX
Graphics
SLI Enabled
Storage
Optical Drives
ASUS DRW-24D3ST
Audio
