Here are the components I've picked thus far:
BUILD #1
Motherboard: ASRock Z97 Extreme6
CPU: Intel Core i5-4670K Haswell
GPU: ASUS STRIX-GTX980
RAM: G.SKILL Ripjaws Z Series 4x4GB DDR3 2133
PSU: Corsair AX760i (760 Watt)
HDD: Seagate 4TB Hybrid Drive
Wireless Adapter: ASUS PCE-AC56
My question is twofold:
1) How does the build look to you all? Are there any
pieces seemingly incompatible? or any changes/
recommendations to be made? Bottlenecking? Heat
issues (stock coolers w/ no OCing)? Diminishing returns?
2) Missing from the above list is a case and that is
the second part I am seeking input on.
In the future, I envision adding:
• 2x SSDs
• 2x HDDs (for a total of 3 HDDs in the system)
• 2 optical Drives (BluRay Read/Write)
• Sound Card (Soundblaster ZxR?)
• An additional GTX980 (may hold off till I get a
better MOBO)
• Water Cooling System (probably hold my
radiators in a radbox)
Important to me are:
• build materials (prefer metal and glass, but durable
plastics are fine)
• cable management
• airflow
• easily accessible drive bays--e.g. toolless,
hot-swappable--and general ease of access to
the insides
• Adequate USB 2.0/3.0 I/O
• Plenty of room for fans, and
• a subdued look is preferable.
I want to set the upper limit for the case to $250 (hopefully it
will be much lower than that): ATX Full/Mid form factor. I am,
however, open to all suggestions. A case that comes with multiple
high quality fans would be a plus (120mm), but I can cope with a lack
if the rest of specs look sharp. I will eventually OC the system when
I can afford a rock solid cooling setup, so tubing, et cetera
friendliness is a plus (note I plan to have an external rad config).
The tone of the Elite PC Roundup article was lukewarm at best, so I thought
I would see what the people of the forums are using/want. Of course I am not
trying to have my cake and eat it too; I expect some compromises will be made,
but I wanted to give you all a good idea of what I am searching for.
Thanks for any and all help/adive you can offer.
Cheers,
Ryan Spooner
BUILD #1
• 2x SSDs
better MOBO)
plastics are fine)
• cable management
• airflow
the insides
Cheers,
Ryan Spooner
