Build crashed after 1 day. Please help
Codylb
13
http://pcpartpicker.com/p/XRPgrH
Quick list of build, everything was running fine until it crashed mid game (ACBF on very high settings) mobo power switch lights up, case fans run when turned on. Nothing on the debug counter on mobo, hyper 212 evo isn't spinning and gpu fans aren't spinning. My keyboard (Logitech g105?) is backlit and doesn't light up when trying to turn it back on. Mouse is backlit and turns on, monitor/hdmi cable don't read computer when trying to boot. Can anyone help?
Thank you,
Cody
Johnnyq1233, I was playing ACBF and out of nowhere the screen went black keyboard wasn't lit up and the CPU lights were off. Turned on the power after a bit because it didn't automatically restart, and what I described before. My only sound is from a headset but it doesn't make any beeps, only on the initial start up there's the feint beep that sounds like it's the case power button or optical drive
Kap, it happened, the case was sealed and I was using my m+kb
OK. Pull the card and try and start the computer with no card.. It will beep because no card but if it does start then you have a dead video card! I know cause my GTX 260 did the same shit on me (same company too.)! Took a lot of searching and testing.. but it is what it is!
You built this computer right?
Did you check temps before you started playing?
Were there any signs of an impending failure (stuttering, flashing screens, etc. )
Was there a surge in the power?
Don't want you to spend hundreds of dollars on hacks messing with your system!
Yes, but unfortunately I didn't check my temps. Everything was running smooth and then it just crashed
Latest posts
