Build Critique or/and Advice
mcdonh
479
This is my build:
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($265.00 @ CPL Online)
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler ($88.00 @ CPL Online)
Motherboard: ASRock Z87 Extreme4 ATX LGA1150 Motherboard ($189.00 @ Scorptec)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory ($189.00 @ CPL Online)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Disk ($109.00 @ PCCaseGear)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($69.00 @ CPL Online)
Video Card: Gigabyte GeForce GTX 770 4GB Video Card (2-Way SLI) ($449.00 @ CPL Online)
Case: NZXT Phantom 820 (White) ATX Full Tower Case ($259.00 @ CPL Online)
Power Supply: Antec 850W 80 PLUS Platinum Certified ATX12V / EPS12V Power Supply ($289.00 @ PCCaseGear)
Total: $2355.00
(Generated by PCPartPicker 2013-11-04 11:48 EST+1100)
I live in australia so prices are different, I'm not sure I want to go with 770's but I don't know what else to do, my graphics card budget is $1000 give or take $50 or so I would prefer to go with sli as with new gen gpu's you can get the best performance for money. I'm also thinking of getting different RAM but not sure what to get. Any suggestions are welcome 😀
Edit: just to clear things up; it will be used for both high end gaming at a high res and some video/image editing hence the ram
If it's primarily a gaming rig you don't need 16 GB ram, 8 will be fine. Also I suggest Corsair ram. For $1000 you could just go ahead and get a 780 or a titan, also I would change the motherboard to an Asus Z87 Pro as it has built in wifi. I would keep the cpu and the cooler is fine.
its not primarily for gaming which is why I have more ram, in autralia you cannot get a titan for $1000 and even so 2 overclocked 770's is fare better I don't want wifi as it provides a slower connection and I am next to my router anyway, 1 780 is not as good a dual 770's by a long way so thanks, but no thanks. I hope that didn't sounds to harsh but yeah.
Oh, didn't know you were in AU. I recommended A 780 as some people prefer 1 GPU, but if you like SLI go for it! And you are right Ethernet will be much better than wi-fi. Great build mate!
😉 and that is all :)
Yep, have good build
