Yes, I selected DDR4 3600 profile I believe that was defaulted to. Would flashing my bios help in this situation?When you get into your BIOS, have you tried selecting the DDR4-3600 XMP profile for your RAM from there? The system might be trying to use improper timings for the RAM if you set it some other way. Clearing the CMOS should reset that though.
Yes you should. When you have instability or hardware that is not detected properly you update your BIOS.
New BIOS updates add memory compatibility etc.
What is the BIOS version you're on right now?
