Build for 1600€
Alberto376
67
Hello guys im looking for a new pc build and i have no idea about components and what should i get.
I will use it to work on databases (sqlserver) and gaming mostly.
The money i have to spend is 1600€ and im from Spain.
Thanks for the replies and your time.
There you go:
IMO, great build with nice quality pieces.
Couldn't find the PRO Version of W10, it should add a bit more bucks to complete the budget.
Aside from that, with that build you'll be able to play anything you want @1080p 60+ FPS and work with heavy applications perfectly because of the i7
We can switch that 1060 for a 1070 if we cut down some things, that way you'll be able to play @1440p
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor (€299.00 @ Amazon Espana)
Motherboard: Gigabyte GA-H170M-D3H Micro ATX LGA1151 Motherboard (€107.00 @ Amazon Espana)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133...
There you go:
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory (€106.09 @ Amazon Espana)
Storage: Samsung 850 EVO 500GB M.2-2280 Solid State Drive (€187.00 @ Amazon Espana)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (€49.40 @ Amazon Espana)
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB WINDFORCE OC 6G Video Card (€307.92 @ Amazon Espana)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case (€119.21 @ Amazon Espana)
Power Supply: Corsair RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply (€223.79 @ Amazon Espana)
Operating System: Microsoft Windows 10 Home OEM 64-bit (€162.00 @ Amazon Espana)
Total: €1561.41
Generated by PCPartPicker 2016-11-23 16:44 CET+0100
You don't need it, it's not worth the extra money if you don't need the networking features. I wouldn't worry about it.
Here's a build I would suggest - slightly over budget but this has everything you need:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor (€329.00 @ Amazon Espana)
CPU Cooler: Phanteks PH-TC14PE_BK 78.1 CFM CPU Cooler (€69.95 @ Amazon Espana)
Motherboard: Asus Z170-E ATX LGA1151 Motherboard (€156.82 @ Amazon Espana)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory (€104.03 @ Amazon Espana)
Storage: Samsung 250GB 2.5" Solid State Drive (€79.95 @ Amazon Espana)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (€49.99 @ Amazon Espana)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card (€469.00 @ Amazon Espana)
Case: Fractal Design Define S w/Window ATX Mid Tower Case (€95.82 @ Amazon Espana)
Power Supply: Super Flower Golden Green HX 550W 80+ Gold Certified ATX Power Supply (€110.08 @ Amazon Espana)
Total: €1626.64
Generated by PCPartPicker 2016-11-23 17:25 CET+0100
