Build for a Gaming PC, advice?
GeeGeeGaming
Hi guys!
I'm fairly new to this and I'd really appreciate your advice.
I'm wanting to make videos with YouTube Commentary whilst playing kickass PC games on the highest quality.
E.g: GTA V, Gmod etc)
I've already made a PC Part Picker if anyone wants to see the link:
http://au.pcpartpicker.com/p/kQtrQ7
Everything is compatible with each other so don't worry about that, all though I do have some questions.
1.) Is this all decent quality stuff and fairly compatible with the newer games? (I don't necessarily need the newest stuff but I want good quality, you know?)
2.) Will this be easy-ish to build up? I know PCs are not easy to build but will this be pretty simple?
3.) Is there any other options for a component that is cheaper (and/or better quality)? I don't really want to go any more expensive than this budget ($2000).
Thanks in advance! I'm really looking forward to this and I can't wait to hear your opinions.
- Suzi
my advice is drop the i5 and cpu cooler and get an i7 with a cheap air cooler, i7 runs cold at stock speed of 4GHZ while the i5 is 3.5GHZ. plus the i7 is about twice as fast when it comes to vid editing, which you want. will end up being around the same price.
the power supply is not good quality and you should change that. the graphic card is weak for what you want to do.
external hard drive is too expensive.
ill see what I can build and see what you and others might think.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($462.00 @ Centre Com)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($65.00 @ CPL Online)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard ($142.00 @ IJK)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory ($79.00 @ Umart)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($98.00 @ Centre Com)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card ($479.00 @ Centre Com)
Case: Silverstone PS11B-W ATX Mid Tower Case ($58.98 @ Mwave Australia)
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply ($119.00 @ Umart)
Optical Drive: LG GH24NSB0 DVD/CD Writer ($19.00 @ IJK)
Operating System: Microsoft Windows 7 Home Premium SP1 OEM (64-bit) ($139.00 @ CPL Online)
Monitor: AOC e2250Swdn 60Hz 22.0" Monitor ($139.00 @ CPL Online)
Keyboard: Corsair Raptor K40 Wired Gaming Keyboard ($79.00 @ CPL Online)
Mouse: Logitech G602 Wireless Optical Mouse ($62.00 @ CPL Online)
Speakers: Logitech Z130 5W 2ch Speakers ($24.00 @ Umart)
Total: $1964.98
Generated by PCPartPicker 2015-07-08 01:28 AEST+1000
you can change the case to what you like, the internal storage is now 2 TB. but mainly this build has an i7 for the vid editing and a 970 graphics for the gaming. power supply is good quality and can handle the system. everything else doesnt matter much. go for 16 gb ram if you can afford it or go cheaper on the other parts, focus on performance.
