build for a multi-porpuse computer?
Jengotiger
16
Hi there!
I need a computer that I can use for work (video edition) and for gaming, as far as theory goes, it shouldn't be a problem, though I'm a bit too clueless when it's about pc parts, so, I'm looking for advise because I'm not sure what I'm doing...
I looked around the site first and saw someone using this site so, I'll use it as well hope I choose right:
http://pcpartpicker.com/p/3gGBE
this is what I choose, taking in mind that I might need something bigger later, like more ram or a bigger (or faster?) processor without feeling that I'm throwing the house by the window (I might even need to buy different parts here where I live, but that shouldn't be an issue)
I might (or not... depending on how complex this sounds) build it myself
Thank you for your time!
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor ($329.98 @ OutletPC)
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler ($71.99 @ Mwave)
Motherboard: Gigabyte GA-Z87X-UD4H ATX LGA1150 Motherboard ($159.99 @ Micro Center)
Memory: A-Data XPG V2 16GB (2 x 8GB) DDR3-1866 Memory ($134.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Disk ($139.99 @ Best Buy)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($57.98 @ OutletPC)
Video Card: Gigabyte GeForce GTX 780 Ti 3GB Video Card ($659.99 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case ($39.99 @ Newegg)
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply ($59.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($89.98 @ OutletPC)
Total: $1744.87
(Generated by PCPartPicker 2014-03-26 06:35 EDT-0400)
looks quite good, but I have been through really bad experiences with gigabyte mother boards, some how they seem to never work for me (after returning 3 computers with a gigabyte motherboards I had enough)
and regarding my bucket... around 1500 would be ideal (or less, if possible, to have it asap, things like 16gb more ram can be added later) as for the cooler, I need something as silent as possible, if water cooling system is more silent I'll go for it
If you are good at installing water cooling:
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.1588614 ($1,300 w/ $100 discount) I recomend adding 8 more gb of ram
No water cooling, but $1000 with the fancy newegg discount:
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.1592374 (I reccomend downloading 8 more gb of ram
Its gonna look badass when you put it together:
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.1434684 ($1,450 w/ discount)
This is my take on an all purpose super fast at everything PC
PCPartPicker part list: http://pcpartpicker.com/p/3iJV3
Price breakdown by merchant: http://pcpartpicker.com/p/3iJV3/by_merchant/
Benchmarks: http://pcpartpicker.com/p/3iJV3/benchmarks/
CPU: Intel Xeon E3-1230 V3 3.3GHz Quad-Core Processor ($244.98 @ SuperBiiz)
Motherboard: ASRock H87 Pro4 ATX LGA1150 Motherboard ($91.48 @ Newegg)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory ($134.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Disk ($139.99 @ Amazon)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($84.81 @ Amazon)
Video Card: Gigabyte GeForce GTX 780 Ti 3GB Video Card ($679.99 @ Amazon)
Case: Corsair 200R ATX Mid Tower Case ($44.99 @ NCIX US)
Power Supply: Rosewill Capstone 650W 80+ Gold Certified ATX Power Supply ($89.99 @ Amazon)
Total: $1601.20
(Generated by PCPartPicker 2014-03-29 20:18 EDT-0400)
Ehm... no... where did you get that from? Broadwell will have it's own socket.
Why do you recommend those parts StoneKany? Just curious why you would recommend 3rd gen Intel when there's no savings there, and then a Z77 motherboard with a cpu that does not have an unlocked multiplier?
I suggested a third gen in case you want to save some money (I also used this link before and didn't think about change the CPU). Why do you say it do not have an unlocked multiplier?
Just upgrade the MB and CPU to the 4th gen.
Edit:
Here goes a different building: http://pcpartpicker.com/p/3iKRB
what's the difference between i7 and xeon E3?, I thought that i7 was the best?
The e3-1230v3 is a re-badged i7 4770 without integrated graphics which you don't need anyway. The only catch is you can't overclock it, but you save almost $80 over the 4770k, and then you don't need to buy an aftermarket cooler, or expensive Z87 motherboard. Total savings is about $230.
oh I see! thank you!
now it's about I find everything, thank you for the help!
