Question Build For LGA1700
q8xbox360
50
I would like to build a new PC with this specifications:
  • ASUS ROG Strix Z690-A Gaming WiFi D4 LGA1700(Intel 12th Gen) ATX Gaming Motherboard(PCIe 5.0,DDR4,16+1 Power Stages,WiFi 6,2.5 Gb LAN,BT v5.2,Thunderbolt 4,4xM.2 and Front USB 3.2 Gen 2x2 Type-C)
  • Intel Core i7-12700KF Desktop Processor 12 (8P+4E) Cores up to 5.0 GHz Unlocked LGA1700 600 Series Chipset 125W
  • G.Skill Trident Z Royal Series 32GB (2 x 16GB) 288-Pin SDRAM DDR4 4000 (PC4-32000) CL18-22-22-42 1.40V Dual Channel Desktop Memory Model F4-4000C18D-32GTRS
  • ASUS TUF Gaming NVIDIA GeForce RTX 3080 V2 OC Edition Graphics Card (PCIe 4.0, 10GB GDDR6X, LHR, HDMI 2.1, DisplayPort 1.4a, Dual Ball Fan Bearings, Military-Grade Certification, GPU Tweak II)
  • Samsung 980 PRO SSD 2TB PCIe NVMe Gen 4 Gaming M.2 Internal Solid State Hard Drive Memory Card, Maximum Speed, Thermal Control, MZ-V8P2T0B
  • 2x WD HGST 18TB 512MB 7200RPM SATA Ultra 512E SE NP Storage DEVIC
  • ASUS ROG Strix LC 360 RGB White Edition All-in-one Liquid CPU Cooler with Aura Sync RGB, and Triple ROG 120mm addressable RGB Radiator Fans
  • ASUS ROG Strix 850W White Edition PSU, Power Supply (ROG heatsinks, Axial-tech Fan Design, Dual Ball Fan Bearings, 0dB Technology, 80 Plus Gold Certification, Fully Modular Cables, 10-Year Warranty)
  • CORSAIR iCUE 7000X RGB Full-Tower ATX PC Case, White
My Questions Is:
  1. Is This Part Will Give Me The Best Performance & Compatibility Or There Is Recommendation To Change ?
  2. If I Want To Go With Dual CPU For Servers What is the Recommendation Here Need To Be Change ?
q8xbox360
50
1- What will this system be used for?
Heavily Used In 3D Rendering, Video Editing/Rendering, Video Post-Production Using AviSynth & Gaming.
2- Building a dual CPU is totally different.
Provide me latest specifications available for this or close performance to what i have even if little more.
kanewolf
Only some CPUs are compatible with dual (or greater) socket builds. Generally the Xeon Scalable is the choice because the lowest end CPU to the highest end CPU use the same socket.
When you start talking about Xeon CPUs then you have different RAM (registered ECC), different coolers, etc. It is quite different than a desktop build.
Look at Asus -- https://www.asus.com/us/Commercial-Servers-Workstations/WS-C621E-SAGE/
Gigabyte -- https://www.gigabyte.com/us/Enterprise/Server-Motherboard/MD72-HB3-rev-1x
Supermicro -- https://www.supermicro.com/en/products/motherboard/X12DPL-NT6
But you are talking $$$$$ for any of those motherboards, CPUs and RAM.
q8xbox360
50
Ok, Base On Asus Dual CPU Could you give me full specifications for it. please ?
Also base on current specifications i have now. Is there any Recommendations for it to get best performance of it ?
kanewolf
What is the purpose of this build ?
Xeons have fewer tweaks than desktop builds. Why? Because Xeon builds are for stability, rather than ultimate performance.
q8xbox360
50
Ok In this case base on current specifications i have now. Is there any Recommendations for it to get best performance of it ?
Budget and location?
logainofhades
Then I would probably be looking at a threadripper based system instead. Hopefully Zen 3 based TR will be available soon.
PCPartPicker Part List
CPU: AMD Threadripper 3970X 3.7 GHz 32-Core Processor ($2944.72 @ Amazon)
CPU Cooler: be quiet! Dark Rock Pro TR4 59.5 CFM CPU Cooler ($89.90 @ Amazon)
Motherboard: Gigabyte TRX40 AORUS MASTER EATX sTRX4 Motherboard ($499.99 @ Amazon)
Memory: G.Skill Ripjaws V 128 GB (4 x 32 GB) DDR4-3200 CL16 Memory ($549.99 @ Amazon)
Storage: Crucial P5 Plus 1 TB M.2-2280 NVME Solid State Drive ($144.99 @ Amazon)
Storage: Seagate EXOS Enterprise 16 TB 3.5" 7200RPM Internal Hard Drive ($307.99 @ Amazon)
Video Card: AMD Radeon Pro WX 5100 8 GB Video Card ($696.89 @ Amazon)
Case: Phanteks Enthoo Pro ATX Full Tower Case ($119.99 @ Amazon)
Power Supply: SeaSonic FOCUS GX 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($91.89 @ Amazon)
Total: $5899.33
Generated by PCPartPicker 2021-12-09 14:55 EST-0500
Great, Last Thing Is AMD Good For Gaming Too ?
If you wanna semblance between productivity and gaming, then go for something like this...
INTEL
Type|Item|Price
CPU | Intel Core i9-12900K 3.2 GHz 16-Core Processor | $603.00 @ Amazon
CPU Cooler | Noctua NH-D15 chromax.black 82.52 CFM CPU Cooler | $109.95 @ Amazon
Motherboard | MSI MAG Z690 TOMAHAWK WIFI DDR4 ATX LGA1700 Motherboard | $299.99 @ B&H
Memory | G.Skill Trident Z RGB 64 GB (2 x 32 GB) DDR4-3600 CL16 Memory | $359.99 @ Newegg
Storage | Samsung 980 Pro 1 TB M.2-2280 NVME Solid State Drive | $169.99 @ Amazon
Storage | Seagate EXOS Enterprise 16 TB 3.5" 7200RPM Internal Hard Drive | $305.99 @ Amazon
Video Card | MSI GeForce RTX 3070 Ti 8 GB GAMING X TRIO Video Card | $1415.00 @ Amazon
Case | Phanteks Enthoo Pro 2 ATX Full Tower Case | $159.99 @ Amazon
Power Supply | EVGA P2 1000 W 80+ Platinum Certified Fully Modular ATX Power Supply | $169.99 @ Newegg
| Prices include shipping, taxes, rebates, and discounts |
| Total | $3593.89
| Generated by PCPartPicker 2021-12-11 05:08 EST-0500 |
AMD
Type|Item|Price
CPU | AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor | $519.00 @ Newegg
Motherboard | MSI MAG X570S TOMAHAWK MAX WIFI ATX AM4 Motherboard | $289.99 @ Amazon
| Total | $3499.89
| Generated by PCPartPicker 2021-12-11 05:10 EST-0500 |
Add more storage if you want, there is no dearth of room in that case...
Reactions: q8xbox360
