Build help and suggestions please
naybag
34
Hi everyone. I'm looking at purchasing my first gaming pc. I've been reading into all the technical stuff about pc builds and have picked up quite a bit.
This is the PC im currently looking at:
- Case: Antec 300 Gaming Case - Black
- Power Supply: Corsair TX 650w PSU
- CPU: Intel Core i5 3570K 3.40GHz @ 4.40GHz Ivybridge CPU
- Motherboard: Asus P8Z77-V LX Intel Z77 (Socket 1155) DDR3 Motherboard
- Cooler: Alpenfohn K2 Mount Doom CPU Cooler
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 500GB HDD
- Graphics Card: Sapphire HD 7850 2GB
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: OcUK 24x DVD+/-RW SATA Drive
Firstly I'm wanting to get a medium-high end pc which will last atleast 4-5 years. Or can be easily upgradable to keep up with future components.
The build above was my first idea but then I quickly learned that getting a higher end GPU gives better performance on games than getting a overclocked CPU.
So I then thought would it be possible to drop the overclock down to the standard 3.4 GHZ which would save me around £40 and then I can put a stock CPU cooler on which would save me another £50. With the savings I would upgrade the GPU to a 7870 2GB or even a 7950 3GB GPU.
Then if in the future I need to squeeze more from the CPU I can overclock it and get a couple more years out of it.
Any suggestions are appreciated.
im a little confused with what you mean by dropping to 3.4 GHz to save £40.
you could get a i5-3470 instead of the 3570k but you wouldn't be able to overclock it. if you did go with a 3470 you also wouldn't need cpu cooler and the z77 motherboard. you could save more money by getting a B75 of H77 board instead.
another option is to keep the 3570k and use the stock intel fan and use that money to get a better video card. then in the future when you have more money and you want to overclock you could buy a cpu cooler.
Hi thanks for the reply. Sorry I didn't clarify it properly. I'm not building my first pc myself. I will be purchasing a custom build PC from Overclockers and they charge extra to overclock the CPU. So if I didn't get it overclocked by them I could save money.
i live in the US why would they block me from watching there videos? its only a video of a cpu cooler. copyright grounds? funny.
This video contains content from EMI, who has blocked it in your country on copyright grounds.
