Build Advice Build help for a Video Editing PC ?
cyprusxx
24
Hi im building a new video editing PC, Primarily for Premier pro and after effects. Just want to get everyone's thoughts. If everything is compatible and makes sense. Also a couple questions Can the Asus motherboard support the 14th gen with a bios update? Im open to new case ideas but very hard to find 420mm radiator supported cases.
https://au.pcpartpicker.com/user/cyprusx/saved/#view=zcCgP6
CPU
Intel Core i9-14900K 3.2 GHz 24-Core Processor
CPU Cooler
ARCTIC Liquid Freezer III 72.8 CFM Liquid CPU Cooler
Motherboard
Asus PRIME Z790-A WIFI ATX LGA1700 Motherboard
Memory
Silicon Power XPOWER Zenith RGB Gaming 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory
Storage
Seagate Barracuda Compute 8 TB 3.5" 5400 RPM Internal Hard Drive Silicon Power US75 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive Silicon Power US75 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive Silicon Power US75 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Video Card
Zotac GAMING Trinity GeForce RTX 4070 Ti SUPER 16 GB Video Card
Case
Antec Performance 1 FT ATX Full Tower Case
Power Supply
Gigabyte UD1000GM 1000 W 80+ Gold Certified Fully Modular ATX Power Supply
Have you considered the Gigabyte AERO motherboard? It's aimed at content creation, not gamers.
Overall it's similar to your ASUS choice, though it has an extra M.2 slot.
Both boards needs to have BIOS updated for a 14th gen CPU. I'm not 100% sure but it seems both boards can be flashed without a CPU installed.
https://www.asus.com/us/motherboard...helpdesk_qvl_cpu?model2Name=PRIME-Z790-A-WIFI
beQuiet! Pure Power 12 is a better choice, costs a little more - https://au.pcpartpicker.com/product...ertified-fully-modular-atx-power-supply-bn506
Cooler Master MWE V2 is another alternative, a cheaper one - https://au.pcpartpicker.com/product...lly-modular-atx-power-supply-mpe-a501-afcag-3
PCPartPicker Part List
CPU: Intel Core i9-14900K 3.2 GHz 24-Core Processor ($878.77 @ JW Computers)
CPU Cooler: ARCTIC Liquid Freezer III 72.8 CFM Liquid CPU Cooler ($199.00 @ PCCaseGear)
Motherboard: Asus PRIME Z790-A WIFI ATX LGA1700 Motherboard ($499.00 @ PLE Computers)
Memory: Silicon Power XPOWER Zenith RGB Gaming 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory
Storage: Silicon Power US75 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($130.00 @ MSY Technology)
Storage: Silicon Power US75 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($224.00 @ MSY Technology)
Storage: Seagate Barracuda Compute 8 TB 3.5" 5400 RPM Internal Hard Drive ($265.92 @ Amazon Australia)
Video Card: Zotac GAMING Trinity GeForce RTX 4070 Ti SUPER 16 GB Video Card ($1299.00 @ Centre Com)
Case: Antec Performance 1 FT ATX Full Tower Case ($209.00 @ Scorptec)
Power Supply: Gigabyte UD1000GM 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($209.00 @ Scorptec)
Total: $4137.69
Generated by PCPartPicker 2024-04-01 19:49 AEDT+1100
Reactions: Why_Me
thank you ill take a look.
What do you think of the case? Do you know any other good cases that take the 420 rad
is this the one you mentioned
Gigabyte Z790 Aero G ?​
looks like 100$ more but i dont think i need 5 m.2 slots. was there anything else you think makes it better
A few changes. 1TB M.2 SSD w/DRAM cache for your o/s and proggies, and 4TB M.2 SSD for storage so that you don't suck up all your PCIe lanes. You want an ATX 3.0 psu for these RTX 40XX cards and tbh a 850W psu will work fine. This MSI board has better specs including audio codec not to mention it comes with the 14 gen bios preinstalled.
CPU: *Intel Core i9-14900K 3.2 GHz 24-Core Processor ($878.77 @ JW Computers)
Motherboard: *MSI PRO Z790-A MAX WIFI ATX LGA1700 Motherboard ($419.00 @ Mwave Australia)
Storage: *Crucial P5 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($169.00 @ Amazon Australia)
Storage: *Crucial P3 Plus 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($344.00 @ MSY Technology)
Case: *Lian Li LANCOOL III ATX Mid Tower Case ($229.00 @ BPC Technology)
Power Supply: *be quiet! Pure Power 12 M 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($229.00 @ Mwave Australia)
Total: $4032.69
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2024-04-01 20:09 AEDT+1100
A better look at that board, psu and case.
https://www.msi.com/Motherboard/PRO-Z790-A-MAX-WIFI
https://www.bequiet.com/en/powersupply/4161
https://lian-li.com/product/lancool-iii/
View: https://www.youtube.com/watch?v=9zE9Rg6wGvA
I saw the Aero at a slightly cheaper price.
They're both fine. I'm not sure i'd give the Aero the nod even at equal price but definetly not if costs so much.
Total: $4032.69
thank you for the info
I heard i cant use MSI boards because it doesnt support intel's "iGPU"?
View: https://www.youtube.com/watch?v=vmvJYl_2cDg&t=335s&ab_channel=TechNotice
Why do you prefer the lancool over the new Antec
thank you
thank you
I hadn't heard that before. As @35below0 pointed out the Gigabyte Aero G is a solid option.
https://www.gigabyte.com/Motherboard/Z790-AERO-G-rev-10#kf
https://au.pcpartpicker.com/product/2MLFf7/gigabyte-z790-aero-g-atx-lga1700-motherboard-z790-aero-g
You can't use integrated graphics on either Inter or AMD CPUs if the motherboard does not have display out ports (DP,HDMI,D-Sub, or VGA).
Those motherboards make sense only if you buy a CPU without an iGPU.
It does not apply to every MSi board. Just those without display ports for integrated graphics.
do you guys think a 360 rad is good enough for the cpu? its just very limiting case wise with the 420. Are we talking 1% difference in cpu performance?
Also the Antec forces the Rad mount to be hose up which i heard can cause bubbling sounds?
