I like this combo deal at newegg right now with a 120gb ssd
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.2149182
only things missing are a good HDD and Audio card.
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822236625
Audio: http://www.newegg.com/Product/Product.aspx?Item=N82E16829102062&cm_re=creative_audigy-_-29-102-062-_-Product
Is this a good build? Do you suggest more RAM? Will be running large libraries with a couple hundred gigs of sounds like kontakt and east/west and composing songs with over 5 min length and mastering the sound quality of each instrument and the whole track.
Only other use will be for programming and reading e-books which I'm guessing is minimal.
