Thank you for looking at this post, I'll appreciate all the feedback I can get on this one as 100s of these must be posted a day.
-Backstory-
I've upgraded every piece of my computer over the past few years except for my CPU and motherboard and I've decided I need to finally need to bite the bullet and swap them out.
My AMD CPU has been shockingly bad, despite changing out the thermal paste a few months back, it's been running at stupidly high temperatures causing the stock fan to shake the walls during any load more than idle, thermal throttling in games and even overheating and shutting down my PC the other day during BF1. This was the final straw for me so I want to splash out on a cool CPU and an effective cooler to never run into these problems again.
-/Backstory-
I play lots of CPU intensive games like Rust, PUBG, Battlefield 1 and I want to play Assassin's Creed Origins but there's no way I can at the moment. At a bare minimum, I'd like to be able to play BF1 at 1920x1080, 60 fps, no problems. My current bottleneck means that, no matter the graphics options, these games run really poorly (scraping 30fps) which I wish was the other way around. However, I want to continue playing 60fps at 1080 with new games in the near future so a CPU that can smash these games now at a decent price is what I'm after.
*Also note I don't stream or anything like that, with exception to Skype, I run games with no other processes running*
So, my questions are:
1. What is the best value for money Intel CPU I can get? *By value I mean, not necessarily the cheapest but will last a long time and be a capable CPU for years to come* I've had my eyes bulging at the i7 8700K but I'm wondering whether it's overkill especially with a GTX 970, I'm also not sure how much a motherboard would cost alongside it... Which leads me to my next question,
2. Which motherboard would synergise with your CPU? I'm not interested in the slightest in aesthetics, I simply want one that, in the future, could overclock the CPU and will last along with it.
3. What fan cooler should I get? I'm obviously aware of the Coolermaster Hyper 212X but it seems too good to be real, would it be enough for the CPU, will it allow for any overclocking in the future or is there an alternative that may be slightly more expensive but well worth it in the long run? *I already have some Arctic MX 4 thermal paste*
4. What's going to hold my PC back after I upgrade to these parts? I'm looking mainly at my GTX 970 and Ballistix 16GB DDR3 1600 MHz RAM... I can accept that my graphics might have to come down on newer titles but as long as I can hit 60 I'm not fussed or financially fussed about upgrading my GPU.
Here is my current build: https://uk.pcpartpicker.com/user/WildMitchell/saved/#view=ty6YrH
*I have windows 10 on the HDD, I have a feeling 7 doesn't work with some of the newer Intel CPUs :/*
I should mention my maximum budget is ~£700 (~$930) for absolutely everything, MOBO, CPU, cooler and case etc. but by no means do I want to spend this much unless it's worth every penny.
Realistically, I expect to spend ~£450 (~$600) on CPU, MOBO and cooler but, again, I'd sooner bite the bullet now and not have to worry about a big upgrade for years to come then to next year find out I can't play the new Assassin's Creed or whatever, it is all about value for money.
Thank you very much for taking the time to read this, please feel free to add in your two pence in and get a discussion going, I can guarantee you know more about the subject than me
Cheers!
-Backstory-
-/Backstory-
Cheers!
