Build Help please
Mac070
Admirable
BANNED
Do I just built my computer .
Evga 500b psu
8gb dual channel ddr3 2400mhz
Amd fx 6300
Asus r9 290 reference
1tb western digital 7,200rpm
Nzxt s340 case
Gigiabyte motherboard atx
So yes I know the psu is low on wattage but it's all I have right now .
I need to monitor my temps . I used hw monitor . It said my card was 201farienheit max . What's a better monitor ? And what can I do for cooling that's under $50? Thank you
H7 Cryborg is a great cooler.
Use coretemp, I've been using that software for probably 7 years now to monitor temps for my CPU and it's excellent.
BTW...UPGRADE THAT PSU ASAP!! Don't play anything very demanding until you get at least a 650W psu. FX 6300 is also a bottleneck for that GPU so get a fx 8320 when you can. 😉
If you play any type of demanding game it will bottleneck. Guaranteed. Even if overclocked.
