Build help( which has more performance and future proof)
Benqth
37
My pc specs are
I5 4590
AsRock H97 Performance
8GB Kingston hyperX fury 1600mhz
Seasonic M12ii evo 620watt
Coolermaster CM 690 lll
OCZ Arc 100 240GB SSD(I only play BF4, Csgo, GTA V)
GTX 960 G1 Gaming 2GB/ Sapphire Nitro R9 380 4GB WHICH TO GET!!!!
Windows 10 64 BIT OS
BTW THE GTX 960 is $375 in my country and R9 380 is $360 could you guys help me!!!
Where and why? The r9 380 is the better gpu,but only by a small margin.The 4gb of vram might make it more suitable for the future.
If these are reasons for you to get nvidia be my guest,that's a choice you have to make.There's no 10fps difference.
But ppl say to avoid the R9 380
So I ain't sure which to get. I like NVIDIA's driver software and shadow play. Lastly what's the fps difference between the two GPU in BF4? Is it more than 10fps?
