Question Build help
Jul 20, 2023
19
I’d like to use my old gpu,psu,ram,memory and windows. Need recommendations for cpu and motherboard replacement.
Old build
Cpu
:Intel Core i7 6Gb/s USB 3.1 ATX Motherboards - MSI PRO Z270-A PRO LGA 1151
Gpu: GIGABYTE GeForce GTX 1080 G1
Ram:CORSAIR Vengeance LPX 16GB (2 x 8GB) DDR4 3000 (PC4 24000
Storage: ssd Samsung 250gb(might upgrade to 2 tb
Psu: rm850x
OS: windows 10
New build
Cpu
: Intel Core i3-12100F 3.3 GHz Quad-Core Processor
Motherboard: Gigabyte B660M DS3H AX DDR4 Micro ATX LGA1700 Motherboard
Gpu, Ram, Storage, Psu, OS: same
Someone said I could build an i3 and it would run circles around my old build so I have this setup on pc builder chosen let me know if I can improve on this. Looking to keep it near the same budget. If any compatibilities occurs let me know as I’m a noob.
Your plan is good.
I would not be penny wise and pound foolish by buying the F suffix processor to save some $25.
If you ever have a graphics issue, integrated graphics will keep you going.
We all have a budget, and a i3-12100 is a reasonable processor.
Here is a review:
That said, if your budget permits, see if you can't go stronger.
Perhaps to 13400.
Here is a review:
Reactions: Peter Ferrari
Your plan is good.
Here is a review:
Perhaps to 13400.
Here is a review:
Thanks!!!
I’ll get the 13400 then. this comp actually crapped on me(dead mb) and the motherboard I have listed there is replaced(same brand) but now im getting no output to display. Even with vga. I managed to get an image once but the pin on the cooler fan broke so I replaced that and now no image again so basically thinking I should spend as little as possible or just build an entire new pc.
Thanks!!!
same as 12400, but more pricey.
Not exactly the same.
I5-12400 has 12 processing threads and a total passmark rating of 19538. Single thread rating is 3531. Not bad.
I5-13400 has 16 processing threads with a rating of 26206 and a single thread rating of 3836.
It is the single thread performance that games need most.
You get what you pay for. There is a continuous spectrum of price/performance.
FWIW:
I5-13500 20 32474/3957
I5-13600K 20 38442/4187
