Build Pc for 3D Hi-res Modeling
DurairajR
Hi,
I am planning to build new pc for 3D Modeling and 2D drawing.
Mostly i use to work on
Maya,
MudBox,Zbrush,photoshop Mari and Hair simulation.
(particularly Hi- res mesh and 4k image work purpose).
Rendering is not often.Maxium i do view port render like real time render software
Keyshot and marmoset monkey
I wouldn't play gaming at all.
I Bit new to build a pc,Guide me is it a right choice are Not.
Here is my configuration,
CPU: Intel Core i7-4790K 4-Core 4.0GHz
GPU: Nvidia GeForce GTX 960 Asus Strix DirectCU II OC 4GB Edition
Mobo: ASUS Z97-A
Storage: Samsung SSD 840 EVO 250GB
Storage: Western Digital WDC WD10EZEX 1TB
RAM: 1x Corsair 8GB 1600MHz DDR3 RAM
Case: Cooler Master Elite 431 Plus
PSU: Corsair RM650
Monitor: Dell UltraSharp 24" Monitor – U2414H Full HD
From
Durairaj
from India
a couple of things:
a) u did not mention your budget
b) we have 850 evo, why not go for it instead of the 840 evo?
c) instead of 1 X 8 GB, I recommend 2 X 4 GB sticks
d) u can save some by selecting a non-overclocking cpu and a motherboard
a couple of things:
Hi,
Thanks for the response,
I forget to mention the budget..My Budget is below Rs: 90000 ($1300)
Mudbox software require more power like Workstation system.so that i chosen this CPU and Motherboard.
Query
Is overclocking CPU give any issue for this work ?
Can i know which cooler best for this CPU (4790k)?
shall i go 2x8 16GB ram?
I am bit new for this suggest me best configuration for this.
Thanks
durairaj
overclocking give you no problem if you make sure that a) smps can withstand it, and b) heat dissipation is adequate
there is many options for heat sinks/cpu coolers, but i would go with cooler master hyper 212 evo or its more recent cousins
on the ram, sure
your configuration is very high end and neat; it should last you about 5 - 8 years easily
