Build recommendation and advice
aakashgoyal
9
Hi there,
Approximate Purchase Date: in 2-3 weeks
Budget Range: $450-520
System Usage from Most to Least Important: gaming, programming, lil bit of graphics designing
Overclocking: No
Crossfire: No
SLI : Yes
Monitor Resolution: 1920x1080
Buying Monitor, KB, Mouse, Case, HDD : No(Already have a 120GB Kingston HyperX SSD, Dell ST2240L monitor)
Additional Comments: Intel and NVidia preferred
Shortlisted these components:
Processor : Intel Core i5-4570 Haswell 3.2GHz LGA 1150 - $199
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116896
MB : MSI Z87-G43 LGA 1150 Intel Z87 - $104
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130694
RAM : G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 - $80
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
GPU : MSI N650ti-1GD5/OC BE GeForce GTX 650 Ti BOOST 1GB 192-bit GDDR5 - $134
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127731
Total - $515
Any advices, recommendations ? Are these components compatible with each other ? I need to keep it around $520 and prefer buying from newegg.
Updated the question format. Please give some suggestions for GPU as well.
Alright I have updated the following :
1) CPU : AMD FX-6300 Vishera 3.5GHz (4.1GHz Turbo) Socket AM3+ 95W - $119
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286
2) Motherboard - MSI 970A-G46 AM3+ AMD 970 - $79
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130637
3) Graphics Card
MSI R7850 Twin Frozr 2GD5/OC Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 - $109
www.newegg.com/Product/Product.aspx?Item=N82E16814127663&ignorebbr=1
ASUS GTX650TIB-DC2OC-2GD5 GeForce GTX 650 Ti BOOST 2GB 192-bit GDDR5 PCI Express 3.0 - $139
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121728&ignorebbr=1
Which graphics card should I go for ?
Latest posts
