In the forums, the latest build recommendations for Autodesk Fusion 360 are nearly 2 years old (March 2017), so I'm looking for a current recommendation.
The minimum system requirements are easy to find, but what I really want is to find the sweet spot between performance and cost.
Minimum requirements (not helpful)
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/System-requirements-for-Autodesk-Fusion-360.html
Thanks!
Thanks!
