[Build Request] Planning to build $1600 gaming PC. Been on a gaming laptop too long. Expertise Required.
ekkstra
42
Approximate Purchase Date: Within 2 weeks.
Budget Range: $1600 (before Rebates) no more than...$1800! (after Rebates)
System Usage from Most to Least Important: Gaming - Movies/Netflix - Surfing the Internet.
Are you buying a monitor: Yes! I'd like to have a 27" 1440p, IPS monitor. 144hz is optional, unless you think I should get 144hz for my games.
Parts to Upgrade: This is mostly a new build but I will be re-using:
RAM - http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144 ] CORSAIR VENGEANCE 8GB [/url]
PSU - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006 ] CORSAIR 750W [/url]
CASE FAN/COOLER - http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099 ] COOLER MASTER HYPER EVO 212 [/url]
If I need to upgrade from any of these, feel free to post a recommendation!
Do you need to buy OS: Yes! I've been using Windows 7, I guess it's about time to upgrade anyway. Windows 10. Here's one that I need opinions on. http://www.amazon.com/Windows-Professional-Builder-Refurbished-Installation/dp/B00LG242A0?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_sfl_title_2&smid=ABS0ZPMP59U4Q ] Windows 7 Pro, Refurbished PC Install.[/url] It upgrades to Win 10 PRO! Should I purchase?
-Please note that if you're using an OEM license of Windows, you will need a new one when buying a new motherboard.
Preferred Website(s) for Parts: Newegg (I've got Premier), Amazon & Microcenter (Los Angeles) about an hour away.
Parts Preferences: I'd prefer AMD's Freesync for video cards since IPS monitors are cheaper than nVidia's Gsync IPS monitors. If you think otherwise please do comment! I can be swayed and will take it into consideration!
Other than that I have no preference.
Overclocking: No.
SLI or Crossfire: More than likely no.
Your Monitor Resolution: 2560 x 1440
Additional Comments:
I do NOT want a full tower case.
Do NOT want fancy bling/LED lighting.
Preferably a quiet PC.
Black color, windowed is preferable.
Simple, practical design.
I was thinking of something like this:
Fractal Design MicroATX or
Fractal Design R5
Additional Comments GAMES: I am hoping to have a build that can play Very High settings or High settings with smooth framerates the variety of games I plan to play. From:
Open World - Witcher 3, Far Cry, GTA V, Crysis 3
Strategy - Total War Series (Rome 2, Shogun, etc), Anno 2070
FPS - CS GO, Battlefield, Rainbow Six Siege
I know not all games posted will get VERY HIGH/MAX settings but I'd like to get it pretty high with smooth frame rates.
-(e.g.: Need to have a window and lots of bling, I would like a quiet PC. Please also list specific software or games you're using)
And Most Importantly, Why Are You Upgrading: I've been on a gaming laptop for 3+ years now and it's starting to fall behind. Also been wanting to build a awesome gaming PC again.
-Include a list of any parts you have already selected with descriptively labeled links for parts. Please do not post only links.
PARTS:
I have already bought:
http://www.newegg.com/Product/Product.aspx?Item=N82E16823816057 ] Corsair K70 - $99 [/url]
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211983 ] SSD 128GB - $40 [/url]
http://www.newegg.com/Product/Product.aspx?Item=N82E16822149408 ] HDD 3TB - $90[/url]
And what I will be re-using:
I don't plan to use any other parts of my last PC, it has 5+ year old parts that probably won't meet my requirements. The tower is also a bit dated (NZXT Guardian 921).
Final Comments: I know it's kinda long but thanks for reading and posting!
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($319.99 @ SuperBiiz)
Motherboard: Asus Z97-A/USB 3.1 ATX LGA1150 Motherboard ($138.99 @ Amazon)
Video Card: EVGA GeForce GTX 980 Ti 6GB Superclocked+ ACX 2.0+ Video Card ($619.99 @ Amazon)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case ($77.99 @ NCIX US)
Monitor: Acer XG270HU 144Hz 27.0" Monitor ($449.99 @ B&H)
Total: $1606.95
Generated by PCPartPicker 2016-03-26 01:18 EDT-0400
Thanks for the list. What'd you think of the refurbished Windows 7?
I have the design r5 and love it. So roomy, great airflow +cable management, and the look is nice and minimalist.
Did an alternative ~$1600 build with skylake for you.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($254.99 @ Newegg)
Motherboard: MSI Z170A GAMING M5 ATX LGA1151 Motherboard ($132.98 @ Newegg)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory ($35.99 @ Newegg)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card ($653.98 @ Newegg)
Case: Fractal Design Define R5 w/Window (Titanium) ATX Mid Tower Case ($109.99 @ Newegg)
Monitor: Acer XG270HU 144Hz 27.0" Monitor ($469.99 @ Newegg)
Total: $1652.92
Generated by PCPartPicker 2016-03-26 05:38 EDT-0400
Nice!
Do you think this build will be able to play my games at max settings?
Hyper 212 is fine and will usually give a reasonable overclock on a 6600k. I don't think $50 of ram should prevent you from getting the latest platform (skylake and 1151). Much easier to do simple cpu and ram upgrades later. Also if you want to really push the OC on the cup later you can eventually buy the awesome but ugly noctua d15 to replace the 212.
