this is my first time build and was wondering if my build is suffecient enough to play BF4 and other upcoming games at 1080p ultra. please give your opinion on this build. i didnt include the case and peripherals and i have windows 8. case would be bitfenix prodigy.
http://pcpartpicker.com/user/daylin_10/saved/dnGxFT
i am debating about getting a 850$ custom gaming pc from USA ( keyboard and mice not included and price will add up to 850$ with bitfenix prodigy)and build it or should i get the Alienware x51 824$ build which includes keyboard and mouse. i will leave pc specs down. if i do choose x51 do you think that GPU is good enough for gaming at 1080p at medium, high or ultra settings.
http://www.dell.com/us/p/alienware-x51-r2/pd.aspx
i would like a small portable build and debating about alienware x51 or bitfenix custom build specs above. i have a PS3 and would trade it in for 200$ and the build comes with keyboard and mouse for free.
what do you think i should get and i was thinking of upgrading GPU on alienware x51 to gtx 760 but it ends up to 1174$. the GPU when you customly change it is 350$ extra. which when you but it sperately cost 230$ so that overpriced. But can you buy gtx760 and change it manually that might be cheaper.
could you give your opinions and suggestions for the build
thank you
thank you
