Alright, I'm going for the whole package here with this build. Please look through my items and help me shave some dollars if possible. For instance, I'm going with the Antec 900 case but is there an equivalent case for cheaper out there that you know of? Also, please share if you have any overall suggestions concerning the build, compatibility issues, etc.. I'm hoping this rig can stay with me for the next 4-5 years and able to play most demanding of games throughout that time. I'll most probably add in another 4850 down the line for CF.
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB ($190)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel ($105)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299
Corsair 4GB (2 x 2GB) DDR2 800 (PC2 6400) ($40)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
Western Digital Caviar SE16 WD6400AAKS 640gb ($75)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
Corsair 750TX PSU ($82 w/ promo code esave15)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006&Tpk=corsair%20750tx
SAPPHIRE 100245L Radeon HD 4850 512MB 256-bit GDDR3 ($140)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102770
Antec 900 Case ($80)
http://www.directron.com/ninehundred.html
Xigmatek S-1283 CPU Cooler ($36)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003&
Xigmatek Retention Bracket ($7)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233019
Samsung 22x DVD ROM/Burner lightscribe drive ($27)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151173&cm_sp=DailyDeal-_-27-151-173-_-Homepage
Windows Vista x64 ($100)
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488
Acer 22" LCD ($180)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3883448&Sku=A179-2240
Total: ~$1080 (including MIB)
Thanks!
Acer 22" LCD ($180)
Thanks!
